| The rudder on my UK Cherub does a similar thing the humming will cut in at about 13Kts and get louder and higher in pitch as speed increases. Putting a small bevel on the trailing edge has worked for other foils that have done the same. Also going over the surface with wet and dry to get rid of any small defects seems to help. This particular rudder is not quite right in general shape and trailing edge is too thick. I have not tried beveling the trailing edge yet as I am probably just going to build a new one. |
Additionally, does the 1/4 cord line sweep forward or back? The rules don't define a foil size or shape so we are fairly free here. You might want to reconsider tip sweep as it could be causing early seperation.
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. |
| Nigel/all: www.philsfoils.com There is an interesting technical section that talks about thickness/chord and other real-world issues for CBs. Phil (and Dave Bradly) are skiff sailors, so maybe a few questions put directly to them could elicit interesting opinions regarding design, construction, stiffness and hum! Try GoldWave for a sound editing program -- if you can get a sample of a tone, I believe GW will let you adjust frequency until you reproduce what you are hearing. Jehardiman, Regarding VGs, I always looked at the leading edge strakes on F-15/16/18 and wondered if there were gains to be had by placing essentially a strake (or skeg) immediately in front of the keel to help glue flow to a higher aspect ratio keel when AoA is either large or unstable -- how often does a keel actually stall, anyhow? Is this a solution where no problem really exists? Extending that idea, are strakes for the rudder a good idea or a bad idea (hydrodynamically speaking, that is)? Empirically (looking around the boat yard) I'd have to say no, but does anyone have any insight into the concept? Thanks! Chuck |
Now fillets and cavitation strakes are an entire other matter. They are fitted to help with flow problems that decrease lift, they do not increase lift of the foil itself.
There are actually many items that must generate vortexes in water to operate properly. For example most of the modern swim fins operate by generating two large trapped vortexes to generate thrust. Not real efficient, but it works well considering it would be rather difficult to have swim fins with high aspect ratio blades. If you are getting unstable vortexes on the surface of the centerboard, than vortex generators will stabilize them. It may not be a good permanent solution, but it is perfectly good as a diagnostic tool. I would use only a few very small ones to start, small triangular wedges about 2 inches long and only 1/4" deep or so tapped near the tip of the center board at a small angle (10 degrees) to the flow direction. Place one or two of these a few inches apart on each side of the board. The tip may be where the problem is since it sounds like the trailing edge will close at a much steeper angle than higher up on the board. If this is where the vibrations are coming from, they would be much exaggerated being at the tip. You could also reshape the tip profile by adding material (such as plastic filler, or layers of tape). If it does not work you peel it off and you have not permanently changed the centerboard. Good luck with your tests. Let us know what you find out. |
| What do you mean by this? (I understand what a chord is..) I think that what you are asking can be answered by saying that the front edge of the cb sweeps back much more than the back edge sweeps forward. The back edge is nearly straight. If you think of an 18ft skiff mainsail circa 1996, with a very bent back top mast and only a very small amount of roach in the leech, you would have a similar shape to our board (but of course upside down). Nigel. |
| The centreboard shown at phil's foils here: http://www.philsfoils.com/Designs/im...hantomSet1.jpg would be a similar profile shape to the board in question, except that ours is much longer, and high aspect. The top half of the board has straight, parrallel leading and trailing edges. However the tip is similar to the one shown here. Thanks again for the replies, I'll be certainly trying a few things and posting the results. Nigel. |
First, the Rn of a narrow CB (say 220mm cord) at 12kts is ~1.1x10^6 so the flow is all turbulent. The whole surface is totally covered with irregular micro vortices that grow to a thickness of 5mm at the trailing edge. All you would do by adding turbulence stimulators to the board is to increase the drag, and possibly move the separation point further up the cord, as they are useless to affect the tip or trailing edge vortices while buried in the boundary layer. In aero dynamics, VGs work because of the desire to stabilize the separation point and prevent flutter by inducing the turbulent transition on the foil. They are not needed in "real boat/ship sized/speed" hydrodynamics and are actually detrimental to getting the separation point as far aft as possible. The tip and trailing edge vortices of a foil generating lift are formed by the rollover of energy in the fluid from the high pressure side to the low pressure side of the foil. Any thing that effects these vortices needs to be able to effect the pressure distribution over the foil; such as tip shape, sweep, and root fillets. This is why I asked about 1/4 cord tip sweep. The swept back LE/straight TE tip shape which causes the flow to sweep up the span is detrimental to performance and causes the generation of a larger tip vortex. Ellipitical tip shapes are not a good shape to use unless the 1/4 cord line is made to sweep forward. Hoerner goes so far as to say in FDL on page 3-6 in the section on tapered wings Quote:
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. Last edited by jehardiman : 11-16-2007 at 12:16 PM. Reason: clarify "move" vice "drag" |
The vortex is self does not generate lift, but it can be used to "bend" the flow of the free stream fluid and cause lift. This effect is used to generate lift on a number of aircraft and other machines that operate in a fluid. I am well aware of what is going on with swim fins, I have worked for one of the larger dive equipment manufacturers. In fact I happen to have a patent in my name on one of the type fins they have been producing since about 1986. What I mean by high aspect ratio swim fins is putting wide wings on each foot would make it hard to kick since they would strike each other as they passed each other. I am not aware of anyone that has made that viable. Someone is making a large single "tail" like fin that you put both feet into and you kick like a dolphin, but most people do not find that natural or comfortable. Quote:
#25
Sorry, another one of my pet peeves, but the vortex cannot effect the "flow of the free stream fluid" in the case of a hydrofoil because the fluid is stationary and static in energy until the work is done on the fluid by the foil. I find that it's a common point of perception problem with many of the useful fluid dynamic mathematical contrivances. What the vortices are is the work (energy transfer) done on the fluid (and they have not only velocity around their core, but also movement in the direction of travel) and to that extent it is possible to recover some energy expended back out of them, as many fast swiming and maneuverable fishes do.Quote:
#26
| High frequency foil singing can be flexing of the trailing edge itself. See: Matveev Konstantin I., and Ivan Ivanovich Matveev, "Hydrodynamic Sound Generation on a Hydrofoil," 1996, 12th Conference On High-Speed Ship Design, Nizhiy Novgorod, Russia. Abstract: Mechanism of sound generation on a hydrofoil is considered. Mathematical model of the hydrofoil 'singing' effect is proposed. The frequencies of 'singing' are obtained. The theoretical results are compared with experiments. Contact the author to discuss: Konstantin I Matveev, email: matveev@hydrofoils.org, website: www.hydrofoils.org Matveev Konstantin I., "Investigation of Hydrofoil 'Singing' in the Carman Approximation," Phystech Journal, Vol.2, No.2, 1996. Abstract: "The effect of hydrofoil 'singing' has been investigated. The mechanism of sound generation is considered and a mathematical model of the process is proposed. The frequency of sound generated by a hydrofoil and the sounf intensity distribution are estimated. Experimental data are compared to calculations. Countermeasures against the hydrofoil 'singing' are proposed." Beveling the trailing edge helps to stiffen it as well as modify the hydrodynamics.
#27
| Here's a paper that discusses hydrofoil singing a bit. What's happening is the trailing edge is flexing back and forth, and each time, it varies the amount of lift and a starting vortex is shed into the flow. The vortex shedding frequency increases with velocity. When it approaches the vibration frequency of the trailing edge, the two reinforce each other and you get singing. Mateev's solution was to round off both the upper and lower surfaces so they met in a sharp trailing edge with a larger trailing edge angle than the original shape. He used a larger radius on the suction side than the pressure side, so the rounding on the pressure side started a bit farther aft. This helped to preserve the aft camber of the original section and minimize the change in hydrodynamic characteristics. The thicker trailing edge was stiffer so its natural frequency was above the operating speed of the hydrofoil.
#28
| I sanded the trailing edge, to make it at an angle to the centreline. The noise definitely changed a bit. I think that it was quieter, but we only had fairly soft breeze. Not clear whether it was faster or not, it seemed about the same. I'll post when further results are discovered. Nigel. |
#29
I also note from the paper that he doesn't list increased drag as a result of singing, but rather than increased drag was the result of the most conventional way of preventing singing when used on titanium foils... That seems to suggest that in some circumstances stopping the foils singing by chopping the trailing edge might actually be slower. Of course I may well be extrapolating far too much from what he doesn't say... |
#30
I think I'd be inclined to make the whole trailing edge as stiff as I could, in the hopes of driving the resonant velocity out of the the operating range of the foil.
| Slow diesel | ron17571 | Diesel Engines | 5 | 10-26-2006 12:57 AM |
| Looking for the plans of humming bird | Wojciech Szczyg | Boat Design | 1 | 10-19-2005 06:09 PM |
| i am lookig for the plans of Humming bird | Wojciech Szczyg | Wooden Boat Building and Restoration | 0 | 10-19-2005 05:24 PM |
| Topaz 28 Slow But Sure | Capt. Chris | Boat Design | 1 | 03-14-2005 08:29 PM |
| 8knots here's 42' of slow | TheFisher | Powerboats | 7 | 02-08-2004 02:34 PM |
