Old 05-26-2006, 06:11 AM
Mychael's Avatar
Mychael Mychael is offline
Mychael
Rep: 125 Posts: 479
Hull speed calculation
Not sure if this is a question I am going to regret asking.
My boat (Keel/sail) is 26 foot (overall), is there an (easy) way for me to calculate what the maximum hull speed would be?
It does not have to be precise to the final .5 of a knot just a ball park figure.
Mychael
Old 05-26-2006, 06:23 AM
frosh's Avatar
frosh frosh is offline
Rep: 44 Posts: 621
Hi Mychael, Depending on whether your boat is light or heavy for it's waterline length, hull shape, and sail size in relation to overall displacement as the main factors. Keeping the above in mind refer to Froude's Law:
http://www.boats.com/boat-articles/D...bers/1255.html
This Law will give you a maximum for a keel sailcraft assuming that it does not surf down a wave or commence planing. Sounds like around 6.5 knots should be definitely achievable, perhaps a little more.
Old 05-26-2006, 08:04 AM
Mychael's Avatar
Mychael
Rep: 125 Posts: 479
Thanks for the link.. Looking at it all I'm sorry I asked. hahhah.
The 6.5 knots you've quoted is close enough for me.
Mychael
Old 05-26-2006, 03:49 PM
TimClark TimClark is offline
Rep: 31 Posts: 110
http://www.sailingusa.info/cal__hull_speed.htm
Old 05-26-2006, 06:38 PM
jehardiman jehardiman is online now
Rep: 1623 Posts: 1,483
Remember, Froude "hull speed" has nothing to do with the maximum speed atainable by a vessel, it will only give you the approximate speed of the first "hump" in the resistance curve. If you have enough power, you will climb over that hump. Depending on several factors, such as length/displacement ratio, sail area/displacement ratio, and stability ratio; speed under sail may be significantly higher.
Displacement Hull Speed calculation Toby P Boat Design 12 04-10-2011 06:29 AM
Power/Speed/Displacement Calculation NB Willawaw Boat Design 12 12-29-2005 07:23 PM
Speed calculation!!! bing2005 Electrical Systems 0 01-27-2005 03:28 AM
speed & Trim angle curve by maxsurf, hull speed Joe Lu Software 1 11-25-2004 07:37 PM
Calculation of the hull panel from Larsson Gades Boat Design 1 09-18-2002 05:42 PM
