Old 02-17-2010, 07:05 AM
BobBill's Avatar
BobBill BobBill is offline
Rep: 104 Posts: 379
Location: Minnesotan wakes up daily, a good start, snow or not, in Gingerville.
Hull: Repair Soft Spot
Reinforcing advice.
On dinghy. Soft spot (worn thin) just behind dagger trunk center of hull.
Roving under glass cloth, epoxy matrix or plain cloth with some carbon to stiffen a bit, epoxy also?
Area about a foot overall including good adjacent hull.
Leave a place better. Congress is the enemy!
"All ya gotta know!" Dog. Winona.
Old 02-17-2010, 08:12 AM
bistros bistros is offline
Previous Member
Rep: 0 Posts: 534
Originally Posted by BobBill View Post
Reinforcing advice.
Depends on core construction, materials used and future use of the hull.
If the hull is cored, you may have to remove damaged core and replace. Wet and soggy damaged core (foam, wood, whatever) will spread and get worse, no matter what surface patches are applied. Wet and damaged core can raise hull weight dramatically - it isn't unusual to find 20 pounds or more water in a damaged foam core. Drying time and getting the water out is an art.
Class rules may limit materials that can be used, and if keeping the hull legal and measurable is an issue, you have to consult the class rules.
Generally, some attention must be paid to the original construction - epoxy does work well on polyester if a mechanical bond is enabled, but polyester does not work well on epoxy. Consult the class association for help, or the original manufacturer if they still exist. Posting pictures here will help a lot.
Certainly, patching with stiffer materials may end up with a better result, but if a future purchaser of the boat is thrown out of a regatta due to illegal materials used, you may have to be careful what you represent the boat as. A 29er ceases to be a 29er if carbon uni is used in a repair with epoxy.
Bill
Old 02-17-2010, 08:21 AM
alan white's Avatar
Rep: 1211 Posts: 3,325
What is the boat made of? Plywood?
Old 02-17-2010, 09:38 AM
BobBill's Avatar
Rep: 104 Posts: 379
Hull REpair Materials
Sorry. Boat is all Glass, inner and outer hull config.
No core, plain lay-up with stiffening via deck section.
Here is pic, although not the exact same boat.
Hull: Repair Soft Spot-001.jpg
Old 02-21-2010, 03:21 PM
Rep: 1493 Posts: 7,447
Mat and polyester should do fine for a boat like that. You can use stich mat if you want to build it more.
Old 02-24-2010, 10:42 AM
BobBill's Avatar
Rep: 104 Posts: 379
Soft Spot Repair
Thanks Gonzo, looks like a good idea, maybe with Steve Clark's suggestion of using pipe insulation glassed in (carbon assist maybe) for strength...another great idea that I never would have thought of.
You gents have my brain working anew.
Here (finally) is a pic of actual spot. It is mostly wear damage. Add the munch from being soft that needs attention and some stronger backing as noted for careless dagger board grounding. No biggie.
Very much appreciate the advice.
Hull: Repair Soft Spot-pa100456.jpg
Old 02-27-2010, 05:36 AM
I can see a wooden block. Make sure it is really dry before you glass over it.
Old 03-08-2010, 05:24 AM
BobBill's Avatar
Rep: 104 Posts: 379
Soft Spot Hull Repair
Gonzo, Thanks, been away doing basketball stuff.
I don't think wood block present, but if so, I will replace.
The plan is to replace or install wood or composite backing for all hardware such as mast yoke, bow eye (new), traveler track, etc, even transom, add access ports, clean out and fix soft spot and smooth a bit, rejoin deck and hull, and refinish the little boat's deck and hull.
Getting close to begin date, after NCAA madness.
Old 03-08-2010, 02:32 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1874 Posts: 3,357
BobBill, this is a great thread with intelligent questions/answers, but the green ink is h e l l on my old eyes.
Hoyt
Old 03-10-2010, 10:54 AM
BobBill's Avatar
Rep: 104 Posts: 379
Soft Spot
Sorry! My screen is a bit off and I have a mild odd color blindness. But am buying a new Westinghouse screen today and will go with dark whatever. I have learned it makes finding the thread end easier, if I was contributing.
Will try dark blue.
Need some help repairing soft spot in floor Stan Bright Fiberglass and Composite Boat Building 16 06-27-2009 02:33 AM
Bad Spot in Stringer Dfrenzy Open Discussion: All Things Boats & Boating 41 06-14-2008 05:04 PM
Soft shell multilayer hull with aluminum frame nathanica Boat Design 2 01-25-2008 03:51 PM
Soft hull repair, Help Searay31 Fiberglass and Composite Boat Building 8 07-29-2006 09:23 PM
Soft bilge hull vs. Hard chined. Are both seaworthy? tdamico Boat Design 34 08-31-2003 08:11 PM
