#31
| Steel |
#32
| copper nickel
__________________ liberty ships were beautiful |
#33
| Stainless of course! Just kidding... -Tom |
#34
| Copper nickle is a great material. I've seen a fishing boat of this with no paint, just raw metal, under the LWL too. Of course it costs too damn much. |
#35
the best usually does I read a report on a sail boat made of the stuff many years ago, unpainted less than .03 mm lost and self anti fouling
#36
#37
#38
#39
| I have seen the plastiki before, nice design. But it does not appear the bottle are used as primary structure. There is some kind of frame surrounded by bottles, I could find no information on what holds this all together. |
#40
| I did a quick search too for the structural aspects of Plastiki. It appears that the structure was a skeleton and bulkhead arrangement of welded plastic, with the bottles inserted into vertical holders, possibility welded too the armature. I would think this is a portion of the build many would be interested in, but with further research I found they made it a lot harder on themselves then they had too and it cost a small fortune to manufacture the boat with this set of processes, which is likely why they don't talk about it much. |
#41
| the armature is 2 thousand milk crates |
#42
#43
| Wasn't the plastic ground up, stuck in a huge, heated press and mashed into sheets so it could be welding up into bulkheads, stringers, etc? |
#44
| Cheapest proven way to build a one-off is wood. Usually plank-on-frame but cold molding comes in close if you do it the NZ way without epoxy until the coatings. They use Weldwood and no vacuum bag usually, all 45 degree 1/8" lams, then epoxy/cloth sheath the outside and epoxy seal the inside. I saw two guys build a 40' ocean racer hull this way in 8 days. The plastic boat is cool. |
| Self Sealing Hull Material | DrCraze | Materials | 41 | 06-26-2010 05:14 PM |
| HDPE hull material | lascraigus | Materials | 7 | 01-15-2010 04:01 AM |
| Help about GRP Hull Material Rules | jooule | Class Societies | 4 | 09-30-2008 12:03 PM |
| Hull Forming Material | Fanie | Boat Design | 8 | 10-28-2007 05:00 AM |
| HDPE as a boat hull material | JonathanCole | Boat Design | 14 | 06-14-2007 02:15 AM |
