Old 03-12-2010, 08:23 AM
SuperPiper SuperPiper is offline
Men With Little Boats . .
Rep: 58 Posts: 277
Hull Length
ISO 12217-2 uses hull length LH in its calculations. LH seems to be different from LOA and LWL. It is defined in ISO 8666 but I don't have access to that standard.
Could someone please post a sketch and/or the formula for LH?
It will be much appreciated.
Old 03-12-2010, 09:04 AM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,604
Lh
SP, I found this reference:
202. HULL LENGTH (Lh) : ( EN/ ISO 8666 §5. 2. 2)
The hull length must not exceed 9,50 m.
Reminder: This measurement does not include rudders and their fittings, bobstay fittings, devoid of devices designed to lengthen the waterline, nor pulpits and pushpits, solar panels and wind vane autopilots.
From the 9.5m racing rules. We may have the standard at the lab-if you still don't have a good enough answer by Monday I'll check.
yes, it is a revolution
Old 03-12-2010, 09:26 AM
ruysg ruysg is offline
Rep: 10 Posts: 23
Definition from ISO 8666:
The length of the hull, LH, shall be measured in accordance with 5.2, one plane passing through the foremost part
of the craft and the other through the aftermost part of the craft.
This length includes all structural and integral parts of the craft, such as wooden, plastic or metal stems or sterns,
bulwarks and hull/deck joints.
This length excludes removable parts that can be detached in a non-destructive manner and without affecting the
structural integrity of the craft, e.g. spars, bowsprits, pulpits at either end of the craft, stemhead fittings, rudders,
outdrives, outboard motors and their mounting brackets and plates, diving platforms, boarding platforms, rubbing
strakes and fenders.
This length does not exclude detachable parts of the hull, which act as hydrostatic or dynamic support when the
craft is at rest or underway.
With multihull craft, the length of each hull shall be measured individually. The length of the hull, LH, shall be taken
as the longest of the individual measurements.
Old 03-12-2010, 09:46 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,842
Sounds like LoD
Old 03-12-2010, 11:40 AM
Rep: 58 Posts: 277
ruysg, thanks for the direct quote. That is great. I will use this information.
But check this link from the dark side. If you scan down to the specs, you will see that LOA, LH and LWL are all quoted. LH is less than LOA but longer than LWL. Now, I'm confused.
http://www.teamspeed.com/forums/luxu...bs-2009-a.html
Sorry about using a powerboat as an example.
Old 03-12-2010, 11:57 AM
gggGuest gggGuest is offline
Rep: 64 Posts: 396
.32 metres - about the size of the pulpit maybe...
Old 03-12-2010, 11:58 AM
Rep: 10 Posts: 23
It's natural that LWL<Lh<LOA. Since Lh and LOA include the hull, they will be bigger than LWL. And LOA normally includes parts not included in Lh, such as pulpits, and swiming platforms.
By the way ISO 8666 doesn't define LOA. I guess the closest to LOA would be Lmax (Maximum Length).
Ruy
Hull length and 'hull speed' dale.frahm Boat Design 6 02-28-2010 04:25 PM
length of hull sidthecoolguy Boat Design 2 09-20-2007 10:38 PM
changing hull length Guest Don Boat Design 6 07-20-2005 10:34 PM
Hull Waterline Length to Beam longngone Boat Design 12 10-22-2004 11:37 AM
Hull Length Extension SuperPiper Sailboats 5 11-04-2003 08:29 AM
