Old 10-25-2006, 03:46 PM
Guillermo's Avatar
Ingeniero Naval
Rep: 2069 Posts: 3,574
Hull form evolution for high performance superyacht.
I don't know if this has been posted before, but I think it deserves a place here.
http://www.sailboat-technology.com/l...acht_Polli.pdf
Old 10-25-2006, 05:01 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Interestiing and well written, I'll read it :-)
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 10-25-2006, 05:28 PM
Stephen Ditmore's Avatar
Rep: 563 Posts: 1,025
Very impressive presentation! But I have some questions & caviats. The shape of the immersed deck wing (best viewed in the inclined waterline view) might impart a turning moment to windward.... no? I haven't read through the entire paper yet.... does the author address the issue of heeled turning moment / weather helm?
I would also caution that the Gary Hoyt manta, with a similar form, was not entirely successful (problematic in waves), and led to Hoyt and designer/partner Richard Roake parting company. Also note the skeptical reception Doug Lord's ballasted trimaran (or monohull with training floats) has received in these forums. This is a road that has been explored before....
Old 10-25-2006, 05:44 PM
xarax xarax is offline
Rep: 51 Posts: 277
This is a water ballasted trimaran, isn’t it? When the hull is SO concave, we can no longer describe the boat as a monohull.
Old 10-25-2006, 06:53 PM
Raggi_Thor's Avatar
Yes, it would not be allowed in any racing rule, but this is not a "rule beater", but a 30m fast yacht independent of rules :-)
www.MBOATS.no
Old 11-01-2006, 01:18 AM
Guillermo's Avatar
Ingeniero Naval
Well, it seems like if Sailboat Technology site has dissapeared!
Just in case, I attach here the article.
Old 11-29-2006, 12:05 PM
brian eiland's Avatar
Rep: 1577 Posts: 2,737
Shades of Hoyt's Manta
Originally Posted by Stephen Ditmore View Post
..I would also caution that the Gary Hoyt manta, with a similar form, was not entirely successful (problematic in waves), and led to Hoyt and designer/partner Richard Roake parting company. Also note the skeptical reception Doug Lord's ballasted trimaran (or monohull with training floats) has received in these forums. This is a road that has been explored before....
When I first saw the aft-wing form in the paper, Hoyt's "Manta" was the first thing that came to mind.
Does anyone have some 'Manta' literature and/or photos they might post on this subject thread or another?? I can't seem to find any readily available.
RunningTideYachts.com
Distinctive Expedition Yachts
Old 11-29-2006, 12:22 PM
Tri Hull Stabilization Configurations
Interesting some of the similarites with some power vessel projects
Dick Newick Tri-Hull Power Vessel
http://www.yachtforums.com/forums/16142-post55.html
Trimarans & the Blade Runner
http://www.yachtforums.com/forums/13353-post20.html
White Rabbit & Trimaran Yachts
http://www.yachtforums.com/forums/general-yachting-discussion/3328-white-rabbit-trimaran-yachts.html
Old 11-29-2006, 12:42 PM
Another Wing Form
The carbon fibre hull of Maiden Hong Kong is extremely narrow with a maximum waterline beam of 3.46 metres, and extends to 8 metres on account of the wings. Each wing has the capacity to hold 5 tons of moveable water ballast used to provide additional righting moment to the canting keel as well as to alter the fore and aft trim of the boat.
Juan Kouyoumdjian
http://www.juanyachtdesign.com/
http://www.dkyachts.com/p2_115.htm
http://www.sailingscuttlebutt.com/photos/04/pong0808/
Another feature of the boat is the rotating and canting mast which can be inclined up to 7 degrees and rotated up to 60 degrees each side.
Last edited by brian eiland : 11-29-2006 at 06:10 PM. Reason: add a couple of other website references
Old 11-29-2006, 04:47 PM
Guillermo's Avatar
Ingeniero Naval
Thanks, Brian.
'Shining', from German Frers jr, was a precursor to Juan's 'Maiden Hong Kong'. GF designed the ballasted wings to avoid the using of canting keel, and Juan put both things together, making beam much narrower.
But those were racing boats. What's interesting about Matteo Polli's design (also inspired in Shining) is to add extra stability when heeled, thanks to the submerging wings, and then bring the idea to performance cruising yachts.
The objective in this design was getting a fast and comfortable maxi, designed to sail in not very heavy conditions. Do you think the idea could be applicable to smaller boats, something in the 40-50 feet range?
Cheers
Multi-Hull layouts evolution of theory and design kach22i Multihulls 9 11-26-2006 09:56 PM
High Performance Boats from Italy(SA) Doug Lord Sailboats 3 03-25-2006 01:12 AM
moldless foam core High Performance hull wetRat Fiberglass and Composite Boat Building 7 01-27-2006 03:34 PM
High Performance Maxi Skiff willy Boat Design 8 09-29-2005 08:55 AM
High Performance Boat design software Kurt Scrudato Software 2 11-02-2003 06:25 PM
