| Huge roach control For the knowledgeable: The current trend toward absolutely enormous roach in mainsails found on the latest ocean racing designs seen in the VOR and Velux etc., and the massive square heads on many of the high performance cats has me wondering how twist is controlled in such a high aspect ratio sail with so much of it's area in the top half of the sail. Any thoughts? Feetup |
| Full battens, stable sailcloths and plenty of leech tension. |
| Square tops The square top on small boats and dinghies(and AC boats) requires a fairly stiff upper mast section but allows you to control gust response with the vang w/o the complications of some rigs and their upper shrouds. The extra area is not really roach since a square head roach is measured from the upper aft point of the square top(peak in gaff terms). A square top can be supported by a modern version of a gaff and not even require full battens- a big advantage in some model sailboats. A modern gaff can also allow an upper outhaul that works identically to a "normal" outhaul-ideal on models but a little complex on full size sails though it can work real well. A square top is not only aerodynamically superior- it represents a simple form of automatic( with an adjustable range ) gust response. |
| Wyliecat 17 Big sail, small boat, simple rig. Extremely fast in light air and a blow... |
| So what would it mean in terms of sailing and handling to use that type of sail shape (I've heard the term "fathead main" used) with a conventional rig and not changing anything else? Mychael |
- Bill Hansen |
| Okay.Now bearing in mind I'm only an owner and have no design skills all I can give you is general information about my boat. So Here goes. Fixed fin keel, spade rudder,26feet LOA. Masthead rig conventional, ie not gaffer or anything else. Loose footed main. Adjustable tension backstay, standard forestay and adjustable tension inner forestay. Selection of genoas from 120% down to storm jib. Weather helm if too much wind for main (before reefing or sheeting out). I soon have to replace my main, can you give me an informed opinion with the information I've given you as to how a "fathead" main might work on my boat.? Mychael |
| Your main obstacle is the backstay. You would need to replace it with running backstays, at least under way with a full main. Reefed down in a blow you could have a fixed backstay depending on the size of the 'chop top.' If your rig depends on a highly tensioned backstay to keep the mast in the boat, it could be problematic. An alternative staying arrangement which supports the mast without high backstay loads would need to be added. Other than the hassle of running backstays in tacks and jibes, your boat handling would be pretty much the same and light to medium performance would improve. |
| So if I had swept spreaders and no backstay then it would work? I doubt I'd want to make that many changes. My boat has dual spreaders but they are straight. Mychael |
| I just looked to refresh my memory how a running backstay works. I recall now as my mates Dragon had them. Just more work for a single hander and they refer to fractional rigs, my boat is masthead so I assume a running backstay would not work even if I wanted them. Mychael |
| When I got my new sail from Hong kong and I opened the package I was shocked at the huge roach in the sail they had sent me. I did not order that!! Any way it was already dead so I just flicked it way with a stick. |
| Huge sailboat simply built | Greenseas2 | Motorsailers | 40 | 05-17-2009 08:57 PM |
| Roach - What Size ? | wadlands | Sailboats | 15 | 12-15-2006 04:05 PM |
| Back to basics. A boat that is simply built with huge volume | Greenseas2 | Boat Design | 8 | 11-06-2006 09:20 AM |
| Huge Cracks | l1quidz | Fiberglass and Composite Boat Building | 1 | 10-07-2005 01:07 PM |
| CE and large roach | Guest | Boat Design | 8 | 10-20-2004 04:24 PM |
