| Thanks for the feedback. This calculation demonstrates that to engineer for extreme sea conditions requires extreme structures. I doubt that very many production boats are designed to withstand this magnitude of force. I will be wise to stay within sight of land with my Sandpiper. |
Sandpiper, That's correct, but that's because Class Society Rules aren't really meant for production boats. And the size you're aiming at is also not customery on production boats!!! But why don't you fit one or two deckbeams on the cabin top, that will reduce the size of the panels and the beams will take most of the loads. You'll need a lot less thickness. And I'll look for an other value for the design pressure, more appropriate for your type of boat (I think 18 kPa is more appropriate). Quote:
Till you go sailing: we'll discuss your look through cabin top and work something out! Regards, Peter Last edited by Dutch Peter : 08-25-2004 at 04:34 AM. Reason: added design pressure |
| epoxy and glass inside and outside? and more | Nordson1960 | Wooden Boat Building and Restoration | 6 | 05-22-2005 09:26 PM |
| Glass over good plywood hull? | Ed Hoban | Wooden Boat Building and Restoration | 10 | 02-11-2005 01:26 AM |
| A Thick Glass Over Ply Hull? | NEILIUM | Wooden Boat Building and Restoration | 12 | 10-09-2004 08:03 PM |
| UK - Fibre Glass Workers Required | MnM Int. | Services & Employment | 1 | 07-07-2004 10:42 AM |
| Want to make a glass Raceboat...But... what lay up????? | RT's | Fiberglass and Composite Boat Building | 2 | 06-17-2004 11:10 AM |
