Old 10-25-2011, 07:53 PM
ryanonthebeach ryanonthebeach is offline
Rep: 61 Posts: 33
How to sail online - basics
Hey all
I’ve started a small basic online sailing course for very basic
sailing edu. Prob way below your sailing level. To help those that are interested in learning to sail. Just looking for some feedback.
Please note, this is early days, still building... busy with the
quiz application so that people can test their knowledge online
How to sail
So it's a basic start to how to sail, with a free sailing course...
Here are some of the lessons:
Parts of a sailboat
Parts of a sailboats rig/rigging
Parts of a sail Types of sails
Man overboard procedure
Let me know if you have any comments or suggestions!
Thanks
Ryanonthebeach
Old 10-26-2011, 11:43 PM
sharpii2 sharpii2 is offline
Rep: 471 Posts: 954
You have good graphics and clear, concise definitions here.
But I think you have a bit of information overload for a beginner.
I would start out with 'mast', 'boom', 'tiller'/'helm', 'sheet', 'halyard', 'rudder', and, 'board'/'keel'. Leave everything else in lubberese for now. Use words such as; "right', 'left', 'forward' and 'backward'.
Knowing what the named parts all do should be next.
Sequence of raising sail should follow that. The concept that, if there is more than one sail, the one furthest to the rear should be raised first and set last.
Ideally, a boat with just one sail should be used as an example. This way the general principle of the thing can be well understood, before complex jargon and the complexity of additional sails is added.
Finally, the four basic points of sail should be described and illustrated with the boat shown approaching a target as seen from a top view, so the new sailor can see where the boom position is likely to be, and from the sailor's view point on the boat. This way, for example, she/he becomes aware of the fact that when sailing upwind toward the target, the boat is never really pointed at it, Instead, it seems to sail past it on the left, then on the right, with the target getting ever closer with each pass.
The concept that the sail should be let out until it flaps, then brought in until it doesn't (except when sailing down wind) should be mentioned time and time again. (over sheeting is the most common beginner mistake.)
This is just for starters. You can start adding the nautical terms in later lessons.
I am highly suspicious of the terms 'perfect' and 'best'. I favor the terms 'inadequate', 'adequate', and 'better', instead, with the first of these closest to being an absolute.
Old 10-27-2011, 06:50 AM
Rep: 61 Posts: 33
Great feedback, thanks Sharpii
Yeah I put a bit of thought into how much complexity to add at what points.... unfortunately the temptation is to add more and more detail since the animations take soooo very much work, keep wanting to cram more information into them.
I like the sequence you mention and will be adding a points of sail animation tomorrow, it's almost ready to go.
Looks like I'll need to do revision on how much information is presented in each step. There are a few steps still to come, that will be added in between these current lessons.
Thanks again
Ryan
Polyester basics Michail Materials 6 09-15-2011 03:05 AM
lofting basics help HO229 Boat Design 59 03-15-2011 10:17 PM
Back to Basics amdega Boat Design 2 02-11-2009 05:26 PM
Basics for newbes ted655 Propulsion 0 07-04-2006 02:04 PM
Basics of Sailboat design flyingdutchmen Boat Design 2 10-22-2002 07:20 PM
