| how to remove sahft and plug I have an seized inboard I want to remove how do I plug the whole with the boat in the water once I take out the prop shaft. |
| "Bostin?" Yikes. You shouldn't have to remove the shaft to pull the inboard. Just slide the shaft down and as far out of the way as it will go before the prop hits the rudder. The stuffing box will keep the seal. You've got just a few more months of sailing weather. I'd say run with an OB as needed and do this job on the hard. Good Luck, Mike |
| Can't remove OMC cobra drive's HELP!!! | burt2 | Sterndrives | 2 | 07-17-2006 12:34 AM |
| How to remove paint from the hull of a riveted aluminum boat? | whalepass | Metal Boat Building | 3 | 04-24-2006 10:23 AM |
| Is ther an easy way to remove stringers? | Saltyredfisher | Boatbuilding | 8 | 05-25-2004 09:13 PM |
| plug | howard | Materials | 0 | 03-23-2004 02:22 AM |
| Plug material | bevan | Materials | 3 | 03-03-2004 10:03 AM |
