Old 08-29-2010, 12:30 AM
dylantorquerol dylantorquerol is offline
Rep: 10 Posts: 36
How much will shipping a Moth cost?
I have found a good deal on an 11' moth sailboat in the UK and I am planning on shipping it to Hawaii. I know its really really far away. Is it going to cost less than $1,000 or will it be totally crazy like $5,000.
Old 08-29-2010, 12:45 AM
apex1
If it fits in a 20ft container you can possibly get it there at around 1000.
Contact Kühne & Nagel
Hapag Lloyd has a online calculator for the main routes where you can find the rates for a entire container.
K&N will most probably provide a bypack which is cheaper.
Regards
Richard
Old 08-30-2010, 08:29 AM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
You can take a modern Moth on a plane as check in...all the guys here are doing it
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 08-30-2010, 10:37 AM
apex1
Old 08-30-2010, 11:43 AM
EuroCanal EuroCanal is offline
Rep: 82 Posts: 75
Apparently they weigh about 30-40kg, so it should be possible. I've taken a similar weight boat on planes (but mine is an inflatable and is packed for transport - biggest bits are the paddles). You see kayaks, and windsurfers being taken from time to time, and I guess it's not much bigger than that, once it's packed.
Avoid United Airlines - they have a crappy after-breakage service.
Old 08-30-2010, 06:48 PM
they are only 30kg and have a 2 piece mast like a windsurfer
http://mcconaghyweb.com/newsite/mach2/
Old 08-31-2010, 08:59 PM
Rep: 10 Posts: 36
wow thanks but I just found one right here in Hawaii! I guess I have to sail one first. Is it worth it after you get good at it?
Shipping a boat from overseas... (Shipping a wooden boat from Finland to Alaska) Spin_Drift Open Discussion: All Things Boats & Boating 27 03-12-2009 08:45 PM
Moth plans Panos_na Boat Design 20 01-12-2006 10:19 PM
Stealth Moth ! Doug Lord Sailboats 1 01-10-2006 03:24 PM
Plywood Moth oceangboy2000 Sailboats 42 01-01-2006 04:20 AM
moth jeff woodstock Sailboats 0 02-06-2004 05:55 PM
