Old 10-17-2006, 02:50 PM
hiracer hiracer is offline
Rep: 27 Posts: 158
How much displacement not due to boat?
36' over deck.
30.3' lwl
11.5' beam
34 hp perkins diesel
99 gallons of diesel
17 gallons of kerosene for heater
120 gallons of water
35 gallons holding tank
SS arch on stern
radar
2 GPSs
Solar power and smart charger
full electronics including SSB, navigation instruments, lights, VHF, AC, invertor, CD stereo, microwave, television, etc.
Monitor self steering
pressure fresh water
Pressure salt water for anchor chain
three anchors and 300' 5/16th chain plus 900' of nylon rode
Sea anchor and drogue, harness, jack lines, tethers
8 or 9' roll up Avon with 5 hp yamaha, three gallons of gasoline
2 20# propane tanks, 3 burner stove with oven
cooking ware, plates, bowls, cups, etc.
Food and clothes for four people for 2.5 month summer trip to Alaska
etc. ????
Question one: Approximately how much does all this stuff weigh above light boat displacement?
4,000 lbs, 5,000 lbs, 6,000 lbs?
Question two: Does the displacement figure provided by N.A. to steel home builder include weight of diesel engine? Does it include interior? What does it include and not include??
Trying to get the displacement of my boat by going backwards at it. I bought it used from homebuilder.
Thanks.
Old 10-17-2006, 04:45 PM
Trevlyns Trevlyns is offline
Senior Citizen/Member
Rep: 461 Posts: 689
My understanding (as an amateur designer) is that displacement can be either weight displacement (the weight of an empty yacht) or volume displacement which is the volume of the immersed part of the yacht in “sailing trim.” Generally however, the displacement mentioned in design literature refers to the volume displacement and would certainly include the mass of the engine, all furniture and fittings, designed fuel and water loads, rigging, sails etc. The architect designs the yacht to “sit” at a certain level in the water (the water line) when loaded – that’s why an empty yacht will sit higher than the designed water line. Another reliable guide as to what the yacht can carry is the pounds per inch immersion figure (or metric equivalent). As its title suggests, it shows how much additional weight would be required to sink the yacht 1 inch lower in the water.
To try and answer question one; I’m sure that all the items you mentioned would be included within the “displacement” specified by your designer. Of course, if you have any further doubt, make contact with the designer.
Old 10-17-2006, 07:16 PM
Rep: 27 Posts: 158
The design displacement is a little over 17,000 lbs. Actual weight after loading cruising stores is 23,000 lbs.
How does the designer know how much tankage the home builder will put in? In my case, there is more than 2,000 lbs of tankage alone. I doubt the designer planned that much tankage or that it is factored into the "official" displacement.
With steel construction, I suspect there is pressure to underrepresent displacement. I gotta believe some of the difference between 23,000 lbs and 17,000 pounds is in cruising stores and tankage.
Don't builders habitually underrepresent displacement? But we are to believe designers never do?
Old 10-17-2006, 09:17 PM
Rep: 1623 Posts: 1,483
Hiracer, the displacement given by the designer is based upon the displaced water with the vessel sitting on her designed waterline with all gear, stores, and crew aboard. This total is based upon the lightship weight (the weight of the hull and all non-removable equipment and minimum fluids) plus the load list. The load list defines the weight of tankage (based upon the designers whim but usually 50%, 75%, or rarely 100%), stores (again some precentage based upon storage volume), outfit (usually some minimum equipment set), and crew. If you have the full builders drawing package it will have the load list and the D&O's which should have the answer to you questions.
If you know all that you are going to carry, just add it up...normaly stores (ediable food and packaging, paper goods, etc) are expended at ~ 3.5-5 lbs/person/day and drinking/cooking water and beverages are ~ 16 lbs/person/day unless a watermaker is installed in which case it varies from 4-12 lbs/person/day. Crew is 165-200 lbs, and a sea kit is ~100-175/person.
Gedunk and pogy bait is extra and ~10-15 lbs/person.
Old 10-18-2006, 12:03 AM
Ike's Avatar
Ike Ike is offline
Rep: 1256 Posts: 1,317
Gedunk and pogy bait. Now there are two words I haven't heard in years.
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 10-18-2006, 03:21 AM
Mychael's Avatar
Mychael Mychael is offline
Mychael
Rep: 125 Posts: 479
And those things would be????
Mychael
Old 10-19-2006, 01:43 PM
Mychael
Personal food, sodas, candy, etc. brought aboard above the normal allowance and stowed in hidey-holes, puka's, and occasionally your rack. Gedunk and mightneeds are one of the major causes of weight growth in boats and ships.
Old 10-19-2006, 06:28 PM
Rep: 27 Posts: 158
I do have those. Just got them a few weeks ago. I'll take a look, thanks.
But really my reverse approach is to determine, roughly, whether the boat is built overweight. The builder was skilled (owns and operates a steel fabrication/building company) but at 23,000 lbs I'm trying to figure out where the weight is coming from.
After running the calculations on the tankage, I'm certainly getting strong hints. That's a lot of tankage for this sized boat.
Old 10-20-2006, 08:09 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
In productin boats it's a problem that designers normally mean the boat in sailing condition when they say "displacement", while sales people want that number to be as small as possible so they talk about light ship weight.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 10-21-2006, 06:49 AM
Rep: 700 Posts: 3,208
"In productin boats it's a problem that designers normally mean the boat in sailing condition when they say "displacement", while sales people want that number to be as small as possible so they talk about light ship weight"
Except of course on the old Westsails where the farmers thought heavier was better, so the fully loaded ,ready for Cape Horn , non stop, weights were in the literature.
A great marketing trick was the top of the companionway hatch combing was opened by pushing on a teak 2X4 .
Felt increadibly substantal like you were going aboard the QM.
Boob Bait for da Bubbas!
FAST FRED
Old 10-23-2006, 01:04 PM
Rep: 27 Posts: 158
But my boat is custom, not production.
Old 10-23-2006, 05:32 PM
Raggi_Thor's Avatar
Yes, I think the designer should give you a weight estimate for each item in the boat, hull, deck, structure, equipment and then a total displacement or a range, so that you can see how much gear you can have.
www.MBOATS.no
Old 11-02-2006, 02:38 PM
Rep: 27 Posts: 158
Well, I got out the plans.
Arrrgghh! Coffee stains right where displacement is stated. Looks like "17,000 lbs F.W." but not sure at all.
Brewer's web posting of the design states its displacement as 17,000 lbs. So that confirms something, but not sure what.
No way a 36' LOD steel sailboat is going to weigh 17,000 lbs fully loaded with cruising stores.
Old 11-02-2006, 04:39 PM
Raggi_Thor's Avatar
Why not?
Can you measure the area of the midship section?
www.MBOATS.no
Old 11-16-2006, 08:08 PM
naval ark naval ark is offline
Member
Rep: 19 Posts: 27
Originally Posted by hiracer View Post
Question one: How much does all this stuff weigh above light boat displacement?
The displacement would certainly include the diesel engine, possibly even a little bit of fuel (if you're lucky). It would include some basic interior, but most certainly not include your arch, SSB, microwave, television, etc. It also wouldn't include the 3 anchors, 300ft of chain, sea anchor, roll up Avon, etc.
It's not unreasonable for a 30ft Lwl steel yacht to displace 17000lbs, as you'll have 4mm plate and relatively little internal structure as the plating will carry a lot of the loadings. However, I would be very surprised if you were anywhere near that figure with the amount of kit that's currently on board!!
30ft displacement boat project maksic Boat Design 3 09-16-2006 02:24 PM
@mail.ru signups banned due to spambots Jeff Forum Questions and Suggestions 1 05-05-2006 10:22 PM
Twin 4.3 leaning due to same rotation props? Shubb Propulsion 17 06-12-2005 10:16 PM
decommisioned sail boat as a displacement cruiser? rickc Powerboats 0 10-21-2003 11:44 AM
Rudder relocation due to change in proprotation Peter K Boat Design 1 05-01-2003 11:06 PM
