| How to find angle for swept back spreaders Existing rig has in line spreaders and runner back stays . I want to change this setup to swept back spreaders and do away with runners . The existing bulkhead has some rot and needs to be replaced . I can only move the bulkhead aft 25 cm because of engine mounting in the way . But how do I calculate the angle and length of the spreaders . Any help is most appriciated . Thanks Kevin |
| If the runners are needed to keep the rig up, 25 cm won't allow enough sweep to eliminate them. You'll need at least 15 degrees and 20 would be better. |
| Loads for swept spreader rig | Guest | Boat Design | 29 | 08-24-2008 07:05 PM |
| Transverse Chine Angle | penningtonjeff | Boat Design | 5 | 12-25-2005 05:01 AM |
| centreboard sweep back angle | hwindhagen | Sailboats | 1 | 12-10-2005 02:23 PM |
| What is transom angle? | chase687 | Boat Design | 4 | 06-29-2005 02:21 PM |
| sidelights mounted on spreaders? | pdq123 | Electrical Systems | 2 | 12-29-2004 01:02 AM |
