Old 10-01-2006, 03:42 PM
Jeandupont Jeandupont is offline
Rep: 10 Posts: 24
How to define the sails for a ship of high performance
How to define the Sails for a ship of high performance of 5 meters whose the total weight of the sailing ship 300 kg ? and had it accommodated on board at the most 3 people in the total of 240 kg more?
Old 10-01-2006, 03:57 PM
Rep: 10 Posts: 24
How many square meters of sails do I need for me to plane a sailing ship of high performance with 600 kg of total weight with peoples on board?
Old 10-01-2006, 04:16 PM
gggGuest gggGuest is offline
Rep: 46 Posts: 373
Its really more about how large sails can you hold up in the weather you will commonly be sailing in. There is a lot in Bethwaite in this sort of area.
Old 10-01-2006, 04:19 PM
Richard Hillsid Richard Hillsid is offline
Rep: 19 Posts: 117
It depends on the force.
The force of the wind
The force of the drag
Old 10-01-2006, 04:48 PM
Rep: 10 Posts: 24
Type about 15 knots for example
Old 10-01-2006, 05:48 PM
Doug Lord
Some facts
I've used the figure of 500 sq. ft.(46.4 sq. m) /per metric ton(2200lb.) for the power required to plane- I think I found it in Marchaj a long time ago. There is a formula: Displacement in lb.'s divided by( LWL waterplane area in sq.ft. times waterline length in feet) which gives a figure that should provide some degree of planing up to 1.5 (I14 about 1.22)-with enough power. From Sailing Yacht Design by Douglas Phillips-Birt.
Pierre Gutelle in "Design of Sailing Yachts" has a whole chapter on planing.
This site is invaluable for all the statistics it provides on high performance boats in the range you're looking at:
Comparison(downwind-has links to upwind comparisons)
Address:http://www.contractsolutions.net/J18...omparison.html Changed:11:53 AM on Sunday, September 3, 2006
Good luck and do as much research as possible.
Old 10-01-2006, 08:41 PM
Rep: 10 Posts: 24
Thank you Doug, through of that site I will have
a good reference and with that I will apply in my project .
16' Keel boat-high performance Doug Lord Sailboats 171 11-02-2009 08:09 PM
High Performance Boats from Italy(SA) Doug Lord Sailboats 3 03-25-2006 02:12 AM
moldless foam core High Performance hull wetRat Fiberglass and Composite Boat Building 7 01-27-2006 04:34 PM
High Performance Maxi Skiff willy Boat Design 8 09-29-2005 09:55 AM
High Performance Boat design software Kurt Scrudato Software 2 11-02-2003 07:25 PM
