Old 03-21-2011, 05:37 PM
PAR PAR is online now
Rep: 3125 Posts: 9,403
Headboards on Bermudian sails have been getting fatter and fatter as the years have progressed. With the advent of full battens, headboards have dramatically increased in size, so much so that they can't use the typical headboard as it would be too heavy. Now you commonly see a small, traditional headboard to which the halyard attaches and a diagonal batten to hold up the extended leach. These are still Bermudians, even though the line is visually getting more blurry.
The primary differences are the gaff is a spar, while the bat wing, square headed Bermudians typically don't have a spar, but a headboard and/or batten. Even though a car batten could have length adjustments in it, I wouldn't call this an outhaul tackle like a spar would have, nor is the sail attached to the spar like a gaffer, as the batten is inserted inside the sail. There are other differences, particularly in shape and rigging, but primarily the gaff rig has a spar at the head of the sail, while a Bermudian has localized stiffeners inserted into the sail and/or a headboard that may serve similar purposes.
Old 03-21-2011, 06:06 PM
Milan Milan is offline
Rep: 279 Posts: 320
Originally Posted by PAR View Post
… Carbon fiber and spectra would solve the dimensions and weight issues for the gaff, so windage issues would next be addressed with internal halyards and lifts. This still leaves the mast shadow, head twist off, mast/sail attachment, boom control, weight aloft, etc. as other concerns. to contend with.
Sail tracks strong enough to accept the torque of the gaff, internal outhaul sheaves and lines, boom vangs, gaff vangs, more carbon fiber and spectra stuff address some of this. …
Patrick Balta, ( http://www.balta.fr/etoilehori2.html ), tried most of these things few years ago. I like result:
High performance Gaff sails?-pourreykjavik.jpg  High performance Gaff sails?-imag0051.jpg  High performance Gaff sails?-horizon-20couasnon-2001.jpg
New High Performance Monofoilers Doug Lord Sailboats 342 01-10-2011 05:16 PM
Small High performance Trimaran? Briggsm Boat Design 6 09-07-2009 10:16 PM
high performance plans needed! gomoto69 Boatbuilding 0 07-05-2009 07:02 PM
How to define the sails for a ship of high performance Jeandupont Sailboats 6 10-01-2006 07:41 PM
High Performance Boats from Italy(SA) Doug Lord Sailboats 3 03-25-2006 01:12 AM
