Old 01-18-2011, 09:52 PM
dylantorquerol dylantorquerol is offline
Rep: 10 Posts: 36
Harken+Ronstan Cam Cleat Accesories: Help!
I have the small sized ronstan cleats on my sailing dinghy, but the cleats don't have fairleads, so its hard to pull on a line from an angle. I like the harken fairleads better as they are lower-friction, but I have Ronstan cleats. If both the fairlead and cleat are the same size but different company, will they fit?
Old 01-18-2011, 10:03 PM
bruceb bruceb is offline
Rep: 153 Posts: 565
They don't make it easy
It depends on the size cleats you have, but most Harkens have different screw spacing than Ronstans. That said, if you measure, there are fairleads that will fit, even if you have to bend them and/or re-drill your mounting plates. Someone used to sell mounting plates with several different sets of holes for just that purpose, but the usual need was for Harken cleats with Ronstan or Nicro-Fico fairleads. If you need it and can give me your hole spacing, I have examples of most of the standard cleats/fairleads/eyestraps and can measure a set for you. B
Old 01-19-2011, 07:03 PM
Rep: 10 Posts: 36
Thanks! I think I might as well just order the ronstan fairleads on APS that are made for my cleat. I was just wondering this because my West Marine only had 1 harken x-treme angle fairlead.
accesories for inflatables Agaponi Materials 0 03-09-2007 03:45 PM
3d cad library Harken gear Windvang Software 3 01-31-2007 11:40 AM
sheeting and halyard loads better than harken josch Sailboats 8 08-29-2006 07:29 AM
boats' accesories signum Materials 1 10-02-2005 07:22 PM
Sunfish cleat support gone bad Haodov Sailboats 1 08-12-2005 09:41 PM
