| Back in the early '80s we saw it so often we didn't even raise an eyebrow. I imagine in most production built, "thick", non-cored, polyester, non-bagged, hand laid hulls you would find a void or "delam" area if you drilled enough holes, especially if the hull was laid up in a non-split mold. |
| "especially if the hull was laid up in a non-split mold." ...is that a funny statement or am I missing something. Paul, why would it be different if the mould split or not...crap lamination is very common on many production boats all around the world, just ask any shippy that works at the yards, we see it , I guess almost every week really. So often when installing skin fittings the same problem is seen...usually simply ignored now it is so common.....
As I mentioned earlier, back in the early '80s voids/delams were also so common it was basically ignored. In those days I had a factory-supplied bevel cutter for the Signet through-hull fittings. Most people didn't. So whenever I was working in a yard I would become quite "popular" and would end up cutting through hull holes in all sorts of boats, power and sail. I would find some void or delam in a high percentage of the thicker, solid laminates. |
| Perhaps this is why the " JUDGE " sided with Halberg Rassy on the laminate issue....its industry standard !. Must be difficult for a boatbuilder to defend themselves against class action. |
| ...thanks Paul, understand what you mean now, Ta, John
| michael, certainly not "industry standard " at all, but unfortunately often found......a bit hard to separate when you see so much of it, but that does not make it right.
| Hard to say Landlubber. About the only time I ever see a surveyor go over a production built yacht is when there is a serious issue to be addressed. Who would waste their hard earned money having a Bavaria 32 forensic surveyed before purchase ? Again, Im not really aware of production laminate standards and what is OK.. I do see all sorts of terrible sloppy secondary bonding handwork on typical production boats. Right now Im looking at a well known production Catamaran in the port. The mast uses Tee Ball shroud attachments. The wide beam on the cat means that the shroud base is very wide. Virtually every Tee Ball swage fitting on the mast is " Pinched " in its socket because the Tee Ball shroud exit angle is much to wide. Well known builder. Makes me wonder. |
| Best Free or Low Cost Marine Design Software? (2008-2010) | Admin | Software | 107 | 01-09-2011 10:42 PM |
| The legal aspects of the build | ddrdan | Boat Design | 19 | 11-10-2010 05:32 AM |
| Building a raft, what is necessary to make it legal? | nickydubs | Boatbuilding | 13 | 02-26-2009 08:52 PM |
| Misil I (Hallberg before Rassy?) for sale in Sweden | Raggi_Thor | Sailboats | 4 | 04-28-2007 05:12 PM |
| legal information | gonzo | Press Releases | 1 | 11-19-2003 01:13 PM |
