| GRP impact from storage cradle Hi, I am new to the forum - a wealth of useful info. I would be grateful for advice on the attached image - just bought the boat, I was told... 'Any loose flakes of antifouling were brushed off but otherwise no further paint removed - it would not be a good idea to remove the gel shield, primers, and existing coats of antifoul to expose the gelcoat unnecessarily. As stated, the hull appears undamaged and in generally good condition - only old underlying layers of antifoul are flaking off in this area which is subject to general abrasion from both the cradle and slings (when launching via crane) which work to loosen old paint.' Almost 'catch22', I am suspicious of the brown color base (gelshield 200 comes in green & gray) looks like resin to me? and if so what to do? |
| It could be old paint, but judging by the thickness and general condition, you should consider knocking all that old paint off, at least back to well stuck paint, feather out the irregularities and repaint. This is a nasty job and hazardous, so protect your self. |
| Thank you - I will keep you updated. |
| grp, foam, grp panels help please | lazeyjack | Fiberglass and Composite Boat Building | 11 | 08-04-2008 06:36 AM |
| Meridian 381 Sedan - Please help to build a cradle | Aurochs | Fiberglass and Composite Boat Building | 0 | 06-13-2007 03:42 AM |
| off trailer & on to cradle ?? | pescaloco | Fiberglass and Composite Boat Building | 7 | 02-22-2007 07:44 AM |
| Cradle to support the mold? | tiger1047 | Open Discussion: All Things Boats & Boating | 0 | 01-25-2007 09:00 AM |
| how to build a cradle for a tri hull boat | bigbearfireman | Fiberglass and Composite Boat Building | 1 | 03-20-2006 08:22 PM |
