| Good boats w/ shoal draft keels? Have any of you sailed a shoal draft monohull that you thought was surprisingly good? By that I mean going upwind well, and not really compromised overall. And I'm thinking about mainstream production sailboats, with the typical keel designs -- simple shallow keels, Scheel keels, wing designs, etc. -- from small daysailors to trailersailors, and larger sailboats too. Which ones have you sailed that were surprisingly good? What do you think made them better than usual? |
| Ive taken a 13 foot catboat upwind against a Rhodes 19 keeled sloop. we could point higher than them and in some cases actually be sailing faster than them. I think it was called a Crosby Fast Cat. This is an old boat, so my reply may very well be completely useless to you, but oh well. Do you consider large centerboarders shoal draft? |
| Here on the Chesapeake, where grounding is part of sailing, center boarders are the preferred trailer sailers. If you hit the bottom, you crank the board up, if that's not enough then go over the side and push. Most of the fixed keel boats produced in both standard and shoal draft will draw four feet standard and 3.5 shoal, at least that ratio. You just get stuck a little closer to the beach but still waist to chest deep. And did you ever notice the resembilance of a wing keel and a Bruce anchor? |
In fact, in the only regatta we sailed against them they actually led or were right in it on every beat. I think they might have been a touch slower downwind, but within the rating. This was a light air regatta. I was really surprised, and I believe the MORC rule was modified soon after to treat these keels differently. I think there was also a big deal being made of the patent and license fees, which limited the appeal. So, if you are looking for a fixed keel that performs well, while providing a shoal draft option, you might look into this. http://www.westboundadventures.co.uk/gallery/yacht/aai |
I'm actually just trying to understand the hydrodynamics of all this. I understand the basics pretty well. But since everything in boat design affects everything else, I wonder how much draft can be compromised without compromising the boat too much -- especially if the effects can be mitigated elsewhere. That's why I'm asking about particularly good shoal draft designs. So to the centerboard fans, your points are well taken, but... Quote:
| Herreshoff H-28. Maybe bigger than you are looking for. But if you could find a good one, I think I have rarely, if ever, sailed a shoal draft monohull, without a keel/centerboard configuration, that could go to weather as well. Robert |
| My father had an Alan Payne-designed Columbia 23 with 1'10" draft. It was **NOT** what you want. If it heeled in a puff, it would slide to leeward yards at a time. Great design for casual sailing in very shallow water, although the construction was questionable. I have a Capri 22 with a wing keel, 2'10" draft. I don't feel at a disadvantage racing against a Saber 28 or Catalina 27. I've never sailed against the 4" fin keel version, though, so I can't comment on the difference. I have not gotten a pot buoy's line tied in a know around the wing, yet. I have often sailed/raced on a Tartan 33 with the Scheel keel. All around performance is quite good, though it's pretty heavy/beamy for light airs. We have a shoal draft Hunter Legend 37 in our fleet. I forget exactly what bulb/wing he has. He has been winning. If you go back to the 1950's, the keel/centerboard boats had quite small centerboards. I think the thought process was "The keel should have 10% more area, I will give it that extra area in a CB." It was found later that a big CB that did most of the work upwind was better. Charley Morgan was among the first to use a big, high aspect ratio board. |
| Gulfstar 40. Sailed and raced on one. Ted Hood design, heavy centerboarder, draws 3'11" with the board up, and 11'3" with board down. Narrow hull, low wetted surface, unbelievably quick for a heavy boat. Points and goes upwind like crazy with that high-aspect 7 foot blade down. We would sail boat for boat with boats of same waterline length weighing half as much. |
| I used to sail on a classic S & S centeboard yawl. 58'3" LOA, beam was 14' 6", and it drew 5' 6" with its board up. It weighed 35 tons. With the big board down, it drew 11 feet and went to windward surprisingly well. Off the wind, we used what we called the "baby" board, something like a fixed trim tab to improve the tracking, located aft of the big board. We got into a tacking duel somewhat with the 12 metre Valiant in 20 knots of wind and did reasonably well until they figured out they were like 3 knots faster upwind then we were and then they just sailed off. I think the reason we managed to do well upwind was partly the design, partly luck, and partly the crew skill. |
| kirby designed nightwind 35 centerboarder, sails upwind with the best of them |
| What makes the slotted foil keel 30 % more effective than a solid foil? Thanks, John |
Solid Wing sails like those used on C-Class cats use slots to great advantage, especially at greater cambers, where separation happens readily. I'm sure Tom Speer can give us all a greatly detailed description and mathematical model for this. I can't. I want to clarify that I am not advocating the Tandem Keel as the best solution. I was simply giving anecdotal evidence as to the performance in a single regatta where I witnessed it in a semi-controlled situation. There were at least two other well sailed WL 24s with normal keels in the same races to compare with. Regarding your rudder, I would not add any wings to the rudder on your boat. |
| Paul, Thanks for the reply. As for the wing on the rudder... I am building a rudder to replace the long blade type on my Precision 18. It's just a prototype I'm playing with. My rudder sticks down about 6 inches below my shoal draft keel. So sailing in 18 inches of water isn't really true because of the rudder length. I took 8 inches off and I'm adding a wing in an effort to make up for the 8 inches. Any thoughts? Thanks, John |
| I think I'd hold off adding the wing on the rudder. Maybe try it out first and see if you really need it. |
| The Ideal Cruiser - a long range passagemaker | D'ARTOIS | Projects & Proposals | 306 | 07-15-2011 07:54 AM |
| Twin keel research | MikeJohns | Boat Design | 125 | 06-16-2009 11:44 PM |
| Are we making any real design improvements?? | Wardi | Sailboats | 199 | 11-04-2008 03:33 AM |
| Monterey Boats - a good choice? | Ian Wilkinson | Powerboats | 4 | 03-01-2005 12:26 PM |
| Altering shoal draft keel? | CaptK | Boat Design | 8 | 10-06-2003 10:54 AM |
