| Gelcoating hull Im glad there's a forum out here for me to ask questions, and ahead of time, thanks for any help. I have a small boat I am just getting to working on that I've had for about 10 years, I have no Idea of the brand or even the size, as I haven't measured it yet, but I would guess about 8-10 feet. I would apreciate it if you guys could tell me anything you notice about it that would help me in finding parts or finding the name of it. I have nearly the whole thing sanded down, the hull into the gelcoat, and the top to the primer. What I would like to know is, should I re gelcoat the whole bottom again, or can I just paint it with some antifouling paint? I still have to find the mast, as its lying around somewhere, but the boom, sail, keel, and rudder I have, so Hoepfully after painting and new hardware it will be water worthy. Here is a pic of it so far: ![]() Any other suggestions would be greatly apreciated. -Dan |
| It's probably not worth the hassle of re-doing the gelcoat. sand it to a nice smooth finish and paint it with an Epoxy or Enamel marine paint. If you plan to leave it in the water, antifouling will help a lot There are loads of small boats like this around, someone might recognise something like it. Good Luck, Tim B.
| Enamel or Epozy you say? are there certain advantages or disadvantages to either, and as for the antifouling, I may just use normal paint because I will be taking it in and out every time I use it. I have some wheels from a Zodiac inflatable that I will make mounts for in the transom and will probably tow it behind my bike the few blocks to the landing(dont laugh, I have no trailer, and I dont want to waste gas in my car for a few blocks). |
| There are single-part "modified" epoxies that will work fine and are simple to apply with a brush or roller/brush (tipping) combination. Gelcoating an existing boat is easily the worst prossible option in terms of difficulty. Antifouling isn't necessary. |
| Advice on Re gelcoating my boat | rich99uk | Fiberglass and Composite Boat Building | 4 | 01-01-2006 10:57 AM |
| differences between nitro hull and vee pad hull | riveramunizaga | Boat Design | 4 | 05-24-2005 10:27 PM |
| what is faster a flat boat hull or a vee pad hull | riveramunizaga | Boat Design | 24 | 05-24-2005 02:18 PM |
| Re-gelcoating a hull, coats? | alexhiguera | Boatbuilding | 5 | 02-28-2005 08:27 PM |
| Hull or hull & deck broke apart during 40-50 mph turn | Jeff | Powerboats | 1 | 07-09-2002 12:27 AM |
