Old 03-13-2006, 06:55 AM
dimitarp dimitarp is offline
Rep: 19 Posts: 89
The fun concept
Sail boat with water turbine and batteries. When wind blow water turbine charge the batteries, and when no wind the batteries drive water turbine who act as propeler. The batteries take place in a vertical kill.
Old 03-13-2006, 06:28 PM
solrac solrac is offline
100% sudaca
Rep: 42 Posts: 138
excuse me, (do not offend)
sounds like somebody revamped again the perpetual motor theory....
think it can barely work properly in the outer space.
"the sum of the kinetic + potential energy is a constant" remember? so, what about friction? (friction=speed loss) may that be used as a complement to charge batteries while sailing? ok, but do not use while regatta time, surely that will drown you to the last 2 places of the sheet... a solar panel will do the job in a preety much cleaner way.
Old 03-14-2006, 05:19 AM
mholguin mholguin is offline
Rep: 15 Posts: 84
If I remember it right, the Axiom, used by the Custeau Foundation, works with a power generating turbine, although it is not its main source of power...
Old 03-16-2006, 04:38 AM
Rep: 19 Posts: 89
Only a part of enrgy that come from wind will be use for charge the bateruies.For example if it is not charging the speed of yaht will be 20knt, if it appear a charging the speed will fall and will be 12 ore even small. So the energy that use to compensate the friction at 20 knt will charge the bateries. For long regatts as regatt round the world this will be more appropriate than anny other system.
Dimitar
Old 03-16-2006, 02:58 PM
Brent B Brent B is offline
Rep: 10 Posts: 14
A simplistic look at this would try and see if such a system would get you to your destination faster than conventional sailing. First pass guess would be that the distance reduction while charging batteries would not be made up by the distance gained under battery power.
One feature displacement boats is wavemaking, leading a "hull speed" (please don't start this thread again) indicating an approx speed above which a lot more drive power is needed. Once you are in this speed range, excess wind power that would otherwise be wasted trying to go a tiny bit faster could possibly be channeled into battery charging.
There is a lot of nonliniarty involved, so simple calculations would be very unlikely to yield valid results.
Brent
Old 03-19-2006, 03:24 AM
Rep: 1623 Posts: 2,343
Your "Turbine" is just another version of a prop with an alternator and as for the amount of energy you will gain; you will need to charge the batteries for 3 days to give an hours motoring under electric motor.
Nice idea
Mike Johns.
Alibre Express for free and fun :) ErikG Software 12 01-03-2012 11:50 AM
Scow moth....fun looking boats alyne Sailboats 8 06-02-2011 01:28 PM
No fun in a leaky boat Acidhouse Powerboats 12 11-13-2005 10:38 PM
Sea sun fun icetreader Boat Design 0 07-07-2005 07:02 PM
Rig modification in a Jeanneau 24 FUN Gades Sailboats 1 12-28-2001 08:09 AM
