Old 02-28-2006, 09:58 PM
JSBKC JSBKC is offline
Rep: 10 Posts: 2
Forestay Load Calculation for Toggle
I've been unsuccessful finding a website to calculate the rig loads on my forestay (O'Day 34, ~ 600 sq sail area, 9/32 wire). Specifically, I'm trying to determine if an Eye Jay Toggle (WestMarine # 453324 1/2" pin - rated at 3400 lbs) is strong enough. Any help greatly appreciated. -
Old 02-28-2006, 10:10 PM
bhnautika bhnautika is offline
Rep: 499 Posts: 489
Size fittings to a bit above the breaking load of the wire, 9/16 about 8000lbs
Old 02-28-2006, 10:34 PM
RHough's Avatar
RHough RHough is offline
Retro Dude
Rep: 714 Posts: 1,622
The diameter of the hole in the forestay chainplate determines what will work. For 9/32 wire the pin should be 1/2" diameter.
Eye-Jaw toggles are built to carry the same working loads as the pin.
If the pin fits properly, the toggle should be fine.
I couldn't find the 3400# rating for that toggle. The rated break strength of 9/32 1/19 type 302/304 wire is about 10000# or about 8500# for type 316. If 3400# is the safe working load, it is in the 30-40% of breaking strength range. I can't imagine an Alexander-Roberts 1/2" toggle being rated at 3400# breaking strength.
Proud supporter of The Far Kurnell Cat Racing Team
I have not failed. I've just found 10,000 ways that won't work.
- Thomas A. Edison
Old 02-28-2006, 10:38 PM
Rep: 10 Posts: 2
Yes the Eye-Jaw toggle has 1/2" pin just like the forstay. The 3400 lbs load seems low to me.
Old 02-28-2006, 10:53 PM
RHough's Avatar
Retro Dude
That has got to be a SWL number, not a breaking load number. I've never seen a eye-jaw toggle break before some other part of the assembly. I use bits from A-R all the time, no problems with the quality.
- Thomas A. Edison
keel load, dynamics water addict Boat Design 0 02-28-2005 12:05 PM
ACC Forestay Location SuperPiper Sailboats 10 09-27-2004 10:37 PM
Forestay tension nemo Sailboats 0 02-11-2004 05:59 AM
heat load calculations thomask Software 1 11-12-2003 10:23 AM
mast load nemo Sailboats 13 08-21-2003 09:14 PM
