#796
| Thanks,Simon! Sure appreciate these pix..... I figured it out Simon,thanks! |
#797
| It is quite an interesting development in near surface foil sections, at least to me, i' ve never seen anything quite like it and it would be very interesting to see some polars for it with some numbers, L/D and so on.
__________________ T.T.T. a.k.a. T³ |
#798
| Note the leading edge is on the right in each picture. Somewhere on this forum are some sketches from Jon Howes and discussion posted about 18 months ago. (Sorry cannot be more precise than that) Simon |
#799
| Here,post 105: Oh Lordy (Doug) |
#800
#801
It seems to me that this foil is quite different actually. Follows the second image as referred to in the above quote from Jon. The Tomahawk foil looks like it is designed to have a reattaching flow at certain regimes. Hopefully Jon can shine some light on these speculations. ![]()
#802
#803
Remember this boat is a pre-production model. Production boats are not expected until the middle of the year. Quote:
Simon |
#804
| I thought out this leeboard/foil arrangement, for putting under the vaka/ single aka joint of a proa. For my purposes, I wanted pitch moments to be resolved in the air mostly anyway, so it makes more sense to me than two foils, one at each end of vaka. If you were using a rig with a large yaw and pitch moment, then it would not make sense. With a kite, those moments can be small, and even automatically changed by towpoint movements. With a masted rig, they could be minimized by ama shifting back and forth, and balanced by extra aero surfaces. |
#805
| Chesapeke Symposium Paper on Foiling Moth By Bill Beaver: http://www.moth-sailing.org/download/CSYSPaperFeb09.pdf |
#806
| Super interesting paper. The drag figures from the hull and tramps makes me wonder why the moths are not doing these things: 1)Lower freeboard 2)netting and not fabric tramp 3)jibing the daggerboard so the hull can point straight into the wind (makes for funny landings at 20kt I guess) 4)International Canoe style seat instead of tramp (with windward heel the lee tramp is the draggiest one I assume) 5) if the tramp sail is removed as in 2 and 4 then it may start to make sense to make gunwales more rounded. ??? |
#807
| Sigurd, I think an IC type sliding seat is against the Moth rules. But new foilers may well take advantage of sliding seats in various forms. |
#808
| [quote=sigurd;265016] ... 3)jibing the daggerboard so the hull can point straight into the wind (makes for funny landings at 20kt I guess) ... /QUOTE] I was looking at this idea as an offshoot of my sailing kayak experiments, and have a test lined up for the summer. It might be worthwhile on slower boats but I doubt much would be gained on a foiler. Once a boat is planing, and definitely if it is flying, it is sailing so close to the apparent wind that the hull drag is already close to optimum. A foil-shaped slab-sided hull would be good under these conditions which may justify the typical moth shape.
#809
| I think I disagree. The hull/tramp (aero) drag is, according to the paper, a good bit of the overall drag at 20kt, and if you look at the drag reduction when heeled to windward, I come to a different conclusion than the author - the tramps look like they may not give less drag, but the hull allows air to go under it easier. Either way, the drag must be less if it is all pointed into the wind. I don't see how this would benefit a lowrider (not flying boat) since the hull would be out of alignment with the water. In fact in a lowrider, the opposite might be beneficial - jibing the board into the wind, to align the hull to the water. This might be what you are planning? |
#810
| Foiler Performance Program From Alan Smith: http://dougculnane.blogspot.com/2009...ions-from.html |
| College for Naval Architecture | Archive | Education | 15 | 04-07-2008 01:42 PM |
| Master in yacht design | ambas | Education | 26 | 05-11-2006 02:47 AM |
| Looking for the right path to design and build | ben_morel | Education | 44 | 11-24-2005 04:51 PM |
| Westlawn Shool of Yacht Design | michal | Education | 9 | 03-07-2004 09:11 PM |
