  #781
Old 02-25-2009, 07:12 PM
Doug Lord
See the posts from Mark Drela and Alan Smith(#154 and #157) here:
New High Performance Monofoilers
  #782
Old 02-25-2009, 08:16 PM
Tcubed's Avatar
Tcubed Tcubed is offline
Boat Designer
Rep: 303 Posts: 415
Front foils must be loaded more than rear foils whether it is yaw or pitch.
However this can be circumvented by other methods of stability.
In the case of pitch height adjusting sensors these will overwhelm natural pitch instability up to a point. I have not researched this enough to give you an answer as to where the limit is. For yaw there is a limit as well and that i can not answer precisely either.
In the case of yaw i made an experiment with a windvane directly attached to a bow rudder, with no linkages whatsoever, and this worked very well. This kept the 'balanced' bow rudder pointing at the given angle to the wind and the rest of the boat 'trailed' behind.
There is though a difference between the systems namely angle fixed reference (and this is not at all fixed because it apparent wind), and displacement fixed reference (which is not so fixed either due to waves).
T.T.T. a.k.a. T³
  #783
Old 02-25-2009, 08:56 PM
sigurd sigurd is offline
Pompuous Pangolin
Rep: 43 Posts: 624
tc if you look at DL's link you will find one answer. about 2:1 cl back /front IIRC. Not a limit ofcourse but practical. There is no limit, you can sit behind the rear foil and have the front foil pull down.
  #784
Old 02-25-2009, 09:32 PM
Tcubed's Avatar
Boat Designer
Rep: 303 Posts: 415
Where exactly do you see that 2:1 , are you really understanding M.D.'s graph or are you seeing something i'm not?
As you say you could have negative loading on front foil with a surface sensor but in a practical, dynamic situation you would eventually find a limit where it becomes uncontrollable due to inertial/pitch heave coupling oscillations.
T.T.T. a.k.a. T³
  #785
Old 02-25-2009, 09:45 PM
Pompuous Pangolin
Rep: 43 Posts: 624
ok 3:1.
"It seems that at high speeds it is acceptable (stability wise) to move the CofG that far aft that you are sailing with a cL on the rear foil 3 times that of the front foil. However best performance will usually be achieved when the cL's of both foils are equal."
^alans
  #786
Old 02-25-2009, 11:05 PM
tspeer tspeer is offline
Rep: 1329 Posts: 1,523
[quote=Doug Lord;257735]...
Question for Tom Speer, Alan Smith and Marc Drela: do you feel that this comment is correct for a two foil monofoiler? "..because the Canard is inherently more stable than the tractor route."
I don't see anything wrong with steering with the forward foil.
As for a canard being more inherently stable, that would depend on details like the sizes of the surfaces, center of gravity location, etc. Some stability requirements are the same, whether it's a canard configuration or an aft tail. The forward surface has to be more heavily loaded than the aft surface for pitch stability. The forward surface has to have a greater heave stiffness than the aft surface for stable pitch-heave coupling.
It's generally the case that the trimmed drag of an aft-tail aircraft is less than the trimmed drag of a canard aircraft, with a tandem wing being worse than either the canard or aft tail. Whether this holds true for hydrofoils would depend on aspects like the influence of the free surface. For example, Konstantin Matveev shows in his hydrofoil tutorial how to position the aft foil so that it takes advantage of the wave generated by the forward foil.
Tom Speer
  #787
Old 02-28-2009, 09:46 PM
Karl Wittnebel Karl Wittnebel is offline
Rep: 26 Posts: 22
Tom where is that tutorial? I looked on his website but didn't find mention of optimizing two foils in relation to each other.
  #788
Old 02-28-2009, 11:52 PM
It used to be on the IHS site. However, I don't see it there any more, and he doesn't have the same discussion on the tutorial on his own website. I believe the formulas are the same, however.
His symbology has always been confusing. For example, he says his Froude number is based on chord length, but his drag equation #6 appears to have two different Froude numbers in it. I suspect Frb is the Froude number based on chord and Frz is the Froude number based on the distance between the foils.
The Froude number for wavelengths equal to the distance between the foils is 1/sqrt(2*pi). When Frz in equation 6 equals this value, the wave drag in his formula goes to zero. That would make sense if the following foil was recovering all the wave drag from the first foil. Hence my suspicion that Frz is based on the separation between the foils instead of the chord.
However, I would expect that to happen when the wavelength was twice the distance between the foils, instead of equal to the distance between the foils. The reason is at one wavelength from the first foil, the flow in the wave should be moving down at approximately the same speed as the downwash off the foil. But if the following foil is located at half the wavelength from the first foil, it will be in an area of upwash. Induced drag comes from the lift vector being tilted backwards by the downwash, and if the upwash from the wave tilts the lift vector of the following foil forward, the two drags can cancel out. In practice, it won't work out quite that well. But I think that illustrates the principle.
Note also in many of his formulas that you see the quantity (h_bar/lambda). His lambda is the aspect ratio and h_bar is the depth divided by the chord. If aspect ratio is span/mean chord, that would make (h_bar/lambda)=(depth/span). So while at first it looks like chord is the most important dimension, it turns out span is really what matters.
Tom Speer
  #789
Old 03-02-2009, 10:31 AM
Paul Scott Paul Scott is offline
Rep: 84 Posts: 272
Slightly off topic- in the latest Windsurfer Magazine (April '09), pgs 74-75 (warning; I think there is a possibility that this article might be an April Fools prank) there is pic and article of a foiler by Rush Randle. (Hydro)Foils are all attached on the bottom of the skeg, main wing forward, small tail aft, vertical tail aft of tail foil, pointing down. He has attached an aero wing on the nose of the board, 8'4" span, 24" at the root, 14" at tip, 2.5" thickness as root, 1.5" at tip. Wing In Ground effect. Says it works well, although he claims (twice!) he can go straight upwind and straight downwind, and can use a smaller sail with it.
The article says that there's a vid of it on the mag's website, but I can't find it yet, so you might have to buy the mag.
A bow WIG might be wand replacement device?
Paul
  #790
Old 03-02-2009, 05:59 PM
Doug Lord
Not on his site yet but who knows...
http://rushrandle.com/hydrowindsurfing.htm
  #791
Old 03-03-2009, 09:43 AM
Pompuous Pangolin
Rep: 43 Posts: 624
paul, sounds weird. if you buy it, any chance you can scan it and put here?
Maybe he can go straight upwind by jumping up and down like the trampofoil?
  #792
Old 03-03-2009, 11:30 AM
Rep: 84 Posts: 272
I did buy it, but it's copywrited stuff. I'm going to leave a message at Windsurfing Mag, and at the photog's site, and see if they'll release a pic to the net.
Paul
  #793
Old 03-05-2009, 07:54 PM
Doug Lord
Surface Ventilated Foils-(no wand)
I'd sure like to hear from Tom,Mark and Alan about these foils-advantages and disadvantages: heres a link and also see the Tomahawk thread:
http://www.tomahawkfoils.com/
Thanks,guys!
This is what Jonathan Howes the inventor says on the site regarding its application on a windsurfer:
"The foil’s inventor, Jonathan Howes*(dl) explains the concept: “It’s a totally new type of hydrofoil that solves many of the problems inherent in conventional foil designs. The ventilated design has features that give a wide operating speed range without moving parts and exceptional tolerance to rough water, making the windsurfer simpler, more versatile and easier to sail”
The concept uses subtle upper-surface shaping to provide progressive changes in lift force with increasing speed in a similar way to an aircraft’s wing flaps but without any moving parts. This means that the windsurfer lifts on to the foils at a very low speed but automatically corrects for higher speeds, giving smooth performance throughout the speed range.
Ventilated surface running allows the foil to move in and out of waves with minimal impact on foiling performance and gives speed potential without sudden changes in handling due to uncontrolled ventilation or cavitation. Not only does it fully exploit the concept’s forgiving characteristics, but a windsurfer fitted with the hydrofoil still behaves like a normal windsurfer. "
I'm not positive but this may be the Jon Howes who is behind the Monofoil concept. I've written to ask him...
Some info on a ventilated foil by Jon Howes here, post105: Oh Lordy (Doug)
  #794
Old 03-06-2009, 10:10 AM
fishwics fishwics is offline
Rep: 10 Posts: 5
It is
Simon
  #795
Old 03-07-2009, 02:25 PM
Rep: 10 Posts: 5
Tomahawk foil photos
Photos from todays Dinghy Show posted at:
http://www.fishwick.demon.co.uk/howesfoil1.jpg ... howesfoil4.jpg
all (c) S Fishwick
picture 1 is a general view of the boat
2 general view of the foil
3 view of top surface against the light to show the shape
4 section of foil at end.
Cheers
Simon
