#691
Hm. What do you think about a jet from a channel along the trailing edge as a substitution for the sharp TE. it could most easily be fed from a symmetrically placed intake (which would be the jet nozzle on the other tack) on the leading edge. Sharp edges, and boundary layer suction to reattach and make it less critical, is another idea. |
#692
| "I don't see that angling the pivot axis helps much with regard to interaction between the daggerboard and rudder wakes. Skewing them laterally may help on one tack but may bring the rudder right into the wake of the board on the other tack." just tack the centerboard if it is an issue. |
#693
http://www.youtube.com/watch?v=1oyWMusaDTI Swept-ish. But watch the end of the video. Instructive. |
#694
| It would be interesting to see a windsurfer with a high aspect Moth type main foil. I wonder if it could jump and re-enter as well as the delta foil? |
#695
| I would like to know what was the thinking behind that sweepback, apart from catching less weeds etc. Sweep like that is not efficient. I'm referring to the image in post #690 btw.
__________________ T.T.T. a.k.a. T³ |
#696
| Quote: Obviously the standard sailboard was in a strong local gust that had not made it to the foiler. If the gust had reached the foiler, it's obvious superiority would have left the "sea-hugger" in the dust. Also, if the incompetent person sailing the foiling board knew what they were doing, they would have been able to jump and re-enter several times, eliminating the remaining nasty hydrodynamic drag and going ever faster yet. You naysayers will soon be proven wrong soon, when Doug's new foiler comes out of the closet this spring. Jumping the foiler is going to be the next quantum leap in performance and fun. You are all going to have to use Botox to remove the perma-grins from your face when Doug posts the video on Youtube. |
#697
| Some pretty gnarly ones there .. Hate to think of wiping out and getting into a little underwater 'encounter' with your own board, all bristling wit blades. Anyone how you's supposed to embed utube vid in here? Well here's the link since the video doesn't seem to want to embed http://www.youtube.com/watch?v=g3AV1LJwQus
#698
Directional foil boards seem to be successful. Nevertheless I would also like to try a twintip foil board. I'd first try Tom Speer's P30110 (a little camber) or P30010 (twice symmetrical) for the main lifting surface(s), since the more cambered sections may not behave properly at low AoA. Strut(s) will be P30010. The main constipation is in the pitch stability. I have sketched some alternatives. I currently favor nr 1 and 4. Nr 1: Likely the front strut will be raked forward a bit, to stop ventilation on its way down to the most loaded foil. Maybe the front foil will also have forward sweep, for the same reason, but if it is not stiff enough this will cause instability since more lift will cause the foil to twist and bend and increase tip AoA. All the foils I can remember have been either unswept or swept back, so for that reason I think I will sweep the front foil back a tad. If I make an inverted T instead of L or inv. Y I can make it oblique instead, which looks cool, but there are twice as many tips to hurt me as an L. Sweeping will delay ventilation and cavitation. The front foil has a smidgeon more AoA than the aft, to be able to load it more, but not so much as to force me out of the water. I am curious as to how you had thought would be best, and what anybody else might think. EDIT: Obviously I will make the foil(s) too long before I cut them down to a manageable AR. And make the tips soft or crushable, somehow (how?). |
#699
| I forgot this one with the pivoting tail. |
#700
| high aspect foils on a windsurfer @doug:I think I've posted this before but: This was my prototype design based on a Rich Miller concept. The first impression of sailing with it are on my site, but basically the long foils provided a lot of damping in roll and they took a lot of ankle stress to contol them. Foilboarding is more about control than efficiency at the moment, as even the inefficient, almost flat plate, initial designs that Neil Pryde were using are way more efficient than a regular board. They just have much less control so you can't use all the available power. |
#701
A draw back of swept back foils is the wingtip vortexs they produce which is the reason why winglets (little verticle fins on the wing tips) were created for some aircraft. Adding winglets to hydrofoils could increase lift by increasing the effective foil area. It is forward swept foils that have interested me because they do not have the problem of wing tip vortices if designed correctly as span wise flow along foil is to the centre where the body of aircraft (or in our case the centreboard part of foil) acts like a winglet, but does not incur the additional drag penalties because it is already there. |
#702
I refer to my post 701 about the some ideas around swept foils. I researched and found one of the reasons forward swept wings are uncommon is that they had difficulty making the strong/light enough and when they did the extra structures within the wing reduced internal payload for fuel, etc. Where as swept back foils twisted less and so were easier to make strong enough. However hydrofoils do not have this problem as they do not need to contain internal fuel tanks like there airbourne counterparts. |
#703
| <<<<<<<<Swept foils either forwards or backwards help with reducing drag at higher speeds increasing the top speed.>>>>>>>> You will find that all aircraft with swept wings have that for mach # reasons which is completely irrelevant in the case of a foil boat. <<<<<<<<<<<winglets (little verticle fins on the wing tips) were created for some aircraft. Adding winglets to hydrofoils could increase lift by increasing the effective foil area.>>>>>>> These winglets inhibit tip vortices yes but come at a price. If the area of the winglet were to simply be used to extend and augment the aspect ratio of said lifting foil you get a pretty similar result. Winglets are not a magic solution, otherwise all planes would have them. <<<<<<<<It is forward swept foils that have interested me because they do not have the problem of wing tip vortices if designed correctly as span wise flow along foil is to the centre where the body of aircraft (or in our case the centreboard part of foil) acts like a winglet, but does not incur the additional drag penalties because it is already there.>>>>>>> This is incorrect. You cannot cheat induced drag by simply sweeping the loaded foils forward. In general, for the kind of flow regimes we're disscusing, any devition from foils at right angles to the flow increases induced drag. I am talking about incompressible attached non ventilating non cavitating flows at M << 1.
#704
ChrisO |
#705
The commercial jets you see with the winglets are invariably working against an overall wingspan limitation at the airports where they operate. Yeah, I suppose they look really cool, but that is not the best way to take the problem to a proper solution. |
| College for Naval Architecture | Archive | Education | 15 | 04-07-2008 01:42 PM |
| Master in yacht design | ambas | Education | 26 | 05-11-2006 02:47 AM |
| Looking for the right path to design and build | ben_morel | Education | 44 | 11-24-2005 04:51 PM |
| Westlawn Shool of Yacht Design | michal | Education | 9 | 03-07-2004 09:11 PM |
