Old 09-18-2008, 02:01 AM
whaletail38 whaletail38 is offline
Rep: 10 Posts: 4
Foil section at low Reynolds numbers.
Can anyone suggest good foil sections to investigate at very low reynolds numbers, approximately 50,000 please?
Old 09-18-2008, 12:47 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2356 Posts: 2,478
Try to look for a research work by Dieter and Althaus, the title is "Profilpolaren für den Modellflug". It is a very nice work on different low-Re profiles, used for aeromodels. It is in german, but the language of graphs is universal.
Old 09-18-2008, 01:29 PM
markdrela markdrela is offline
Rep: 161 Posts: 119
Not enough information. You need to specify a desired Cl range and any structural thickness constraints.
Old 09-18-2008, 08:28 PM
Rep: 10 Posts: 4
The desired cl range is 0.2 to 0.4 and the tickness to cord can go down to as little as 6%. Leeway angles up to 5 degrees.
Old 09-18-2008, 09:09 PM
Rep: 161 Posts: 119
Since you mention leeway, I assume you mean cl = +/-0.2 to +/-0.4 (i.e. a symmetric section). What you want is a thin RC glider tail airfoil. The HT08 or HT12 or HT13 should work well. http://www.charlesriverrc.org/articl...t-airfoils.htm
These have 100% laminar flow in your cl range, and hence are completely immune to low-Re effects, since laminar separation resistance is independent of Re. So if this is for an RC sailboat, they will work OK no matter how low the wind speed.
These show how to hand-sand them accurately in wood, without templates:
http://www.charlesriverrc.org/articl.../tail_sand.pdf
http://www.charlesriverrc.org/articl...il_shaping.pdf
Old 09-21-2008, 03:23 AM
Rep: 10 Posts: 4
Thankyou very much. I'll check these sections out.
Old 09-21-2008, 03:27 AM
Previous Member
Rep: 0 Posts: 0
thanks
Stu
NASA GAW Foil Section Dey Boat Design 3 01-25-2010 04:51 PM
reynolds number for a main acted on by a jib Paul Scott Sailboats 8 05-29-2007 12:26 PM
By the numbers... Help!! qwerty Boat Design 11 10-16-2006 05:00 AM
Reynolds Aluminum Boat timkay2 Metal Boat Building 1 08-08-2005 01:50 PM
Low power tunnel, low speed drive robrohdeszudy Propulsion 9 12-23-2004 05:09 PM
