Old 05-20-2005, 11:58 AM
AYACHT AYACHT is offline
Rep: 10 Posts: 11
Flying Moths
Any good internet sights for building one of the new foil Moths.
Details, Layup, Foil shapes? Looks like fun.
Old 05-20-2005, 03:13 PM
Doug Lord
The Source
Check this out:
http://www.moth.asn.au/forum/index.p...292321c902664a...
The most extensive information anywhere on building, foil areas, control systems sails ect.
I would suggest buying your foils from Fastacraft; contact John Ilett at:
john@fastacraft.com and go to his website: www.fastacraft.com World Championship foils and altitude control system...
Old 05-20-2005, 05:01 PM
Eric Sponberg's Avatar
Rep: 2547 Posts: 1,426
Ayacht,
As a matter of fact, Doug Lord and I are working on a new design for a boat similar to, but better than, a Moth foiler. Doug has put together some ideas on how to make the foilers work better, and I am putting the engineering details together to be able to build them. If you are interested in learning more about the Aeroskiff design, please contact me privately at ewsponberg@sponbergyachtdesign.com.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 05-20-2005, 05:27 PM
astevo astevo is offline
Rep: 10 Posts: 69
by the way the guy in the photo is about to get absolutley nailed.
Old 05-21-2005, 09:55 PM
TaSSie_deVil TaSSie_deVil is offline
Resident Boataholic
Rep: 10 Posts: 38
make a note of the "L" plate on the bow...
another site with hull contruction/engineering would be the AMC moth crew site
http://academic.amc.edu.au/~moth-crew/
the 2nd hull off their mould is just getting it's wings at the moment, has flown once (but broke the foils... back to the drawing board/laminating bench)
"new design for a boat similar to, but better than, a Moth foiler." --- excuse me? The Aerofoiler is yet to "foil". So, how can that be better than a Moth foiler?
Old 05-21-2005, 10:50 PM
cyclops cyclops is offline
Rep: 33 Posts: 1,059
A web search of--moth racing clubs--- moth hydrofoil clubs-- will get you in touch with people near you.
Old 05-22-2005, 07:53 AM
Tassie Devil,
I should clarify that--we ANTICIPATE it will be better than a Moth foiler. Yes, we have yet to prove it, and that will come only from building a prototype and sailing it. What we anticipate is that the boat will be easier to control and, therefore, have less chance of crashing; it should get foil-borne at lower wind speeds, and it should be able to jump effectively and safely. The boat should also be easier and quicker to rig, and put away, on the beach. That is the goal. We think it can be done.
Eric
Eric W. Sponberg
Naval Architect
Old 05-22-2005, 10:14 PM
Resident Boataholic
Rep: 10 Posts: 38
Thanks for the clarification Eric.
I agree, the possibility does exist that the aerofoiler could be far more user friendly than a foiler moth... let's face it, the moth has always been a handfull, irregardless of configuration as a foiler or not. As the aero is a fair bit wider, it should handle a lot better in non-foiling conditions, such as launching and retrieving and low wind conditions. However, I'm doubtful that it'll be quicker to rig than a moth; I can rig my moth (without foils at the moment, but it hardly takes a long time to put in a centreboard and snap on a control cable...) in 15 minutes from scratch (no wings on, only basic sail controls fitted). The rig on the aero (as i've seen in piccys) is far more complex than a simple pocket luff, and as such should take longer to rig.
I'm looking forward to seeing the aerofoiler work, as it is in ways synonymous to Frank + Julian Bethwaites HSP projects... not all of them worked, but they eventually did lend a lot to to the development of modern skiff rigs.
Tassie
Old 05-22-2005, 10:43 PM
Doug Lord
aeroSKIFF 14 foiler
Tasse ,the pictures you've seen are of the aeroSKIFF 16 two person prototype with a main and jib. The new boat uses an unstayed rig with a high speed square top sail and is a singlehander(nominally); we will have help from Barry Spanier one of the worlds best windsurfer sail designers(Gaastra) and the designer of the sails for Long Shot years ago. Stepping and unstepping the mast will be a piece of cake.
The beam on the 14 is 12'(!) substantally more than the original 16 prototype and is that wide to allow lots of righting moment.The beam also allows a fairly small buoyancy pod. Bascally, at this point the "pods" will simply plug in making set up very simple.
The foil loading is less than a Moth but the sail area per sq.ft. of foil area is greater. The weight per sq.ft. of SA is the same but the ratio of righting moment to heeling moment is greater than on a Moth. In addition ,the new boat will carry a max competitive crew weight substantially higher than a Moth while featuring a weight equalization system that allows 140 pounders to sail.
The Moth has been my inspiration for years and has begun a revolution in sailing that I hope this new boat will be part of.
But nothing, no matter how well it sails, takes anything away from the historic achievements in the Moth Class by guys like Ian Ward, John Ilett ,Garth Ilett and Rohan Veal. They are the pioneers that have transformed monohulls into boats faster than catamarans; into boats the truly fly in light air and into boats that redefine sailing efficiency.
Eric and I are workng hard to see to it that the aeroSKIFF 14 meets the targets we've set for it ; the 16 remains under development as we continue to refine it.
Old 05-29-2005, 02:19 AM
ejehn ejehn is offline
Rep: 10 Posts: 2
thanks.
http://anydwg.com
Old 06-08-2005, 09:54 AM
Tiger Moth Tiger Moth is offline
Originally Posted by Eric W. Sponberg
Tassie Devil,
Eric
In reality there is nothing better than a Moth.
Flying Dutchman Restoration Project Andy Wooden Boat Building and Restoration 13 05-02-2007 03:52 PM
Flying Dutchman Linesplan quicksail Sailboats 1 03-24-2005 05:59 PM
Flying Moths Wynand N Sailboats 17 02-22-2005 03:53 PM
the Flying Dutchman and the Sailing Aerofoil foxxaero Sailboats 0 10-27-2002 10:05 AM
flying sub (t.v) Boat Design 0 07-03-2002 09:40 PM
