It can't be welded, it's made of metal that will rust and cause the same problem again, so consider making a new centerboard (what you're calling the keel) of fiberglass with the lead molded inside. This is one area I think 'glass really shines, that is making rudders and centerboards. They don't swell like wood, nor rust like metal and the shape can be accurately controlled, which is a good thing for these parts.
Take an angle grinder to the edge (the ugliest one will be the thinnest) until the metal is worn away and work your way around. At some point, brute force will speed things up, by tearing open the sheet metal skin and dumping out the lead, which you'll want to save, reasonably intact.
You could use the old centerboard as a male plug to help create a female mold, which you can then use to cast a copy of the centerboard in 'glass. I'd use plaster in a shallow tray, place the centerboard in the tray on some short blocks to keep it off the bottom of the tray and then pour in the plaster until it's up to the centerline seam. You'll need one for each side of the board. With the molds made, rip out the lead from the old 'board and toss away the worn out remains. It's probable you'll need to use a release agent on the 'board to get it out of the plaster without screwing it up. I'm not sure if peelply or clear plastic will work for this application, but worth checking into. If all else fails, plain old car paste wax on the 'board will do.
The lead will be much thinner then the 'board is thick (accounting for skin thickness) and some figuring of how thick this will be will be necessary. Once you know how thick your skins need to be you can start the casting process. Using one of the two mold halves, layup some polyester resin and cloth in the mold to about 3/4 or 7/8 of the required skin thickness in the areas where the lead must live. Let this dry overnight. The next day, lay one more wetted out layer of cloth over the area previously done, then place the lead in the mold, insuring goo oozes out all around. Then pack the rest of that and the other mold full of wetted out 'glass. Put the lighter one on top of the lead filled one and clamp the crap out of them. Let them sit until it cures, then break them apart. You'll have a fiberglass centerboard with a lead weight inside. Barrier coat with epoxy (like the hull) then paint.
