Old 01-12-2007, 06:25 PM
Doug Lord
First Use of Foil Assist on Mono Keelboat?
It's coming and this is the closest I've seen yet. ORMA tri's use foil assist to reduce the displacement of the ama when flying the main hull and some monohull keelboats may be able to make use of the same princible.
I couldn't read everything on this site but from what I could read extra vertical lift was not necessarily in the designers plan- but just maybe.....
SYDE Schickler Yacht Design & Engineering
Address:http://www.syd-e.com/beta/ Changed:6:13 AM on Friday, November 17, 2006
(Thanks to SA)
Since I could be wrong about this boat I e-mailed the designer-Doug Schickler- to set me straight one way or the other by posting here. Hope he does...
Old 01-13-2007, 08:20 AM
Doug Lord
--------sy-x 24
Turns out I was right! This design is particularly significant in that it is the first keelboat(that I know of) to use foil assist as part of it's design-great development.
From: (Doug*Schickler) Date: Sat, Jan 13, 2007, 1:07pm (EST+6) To: lorsail@webtv.net (Doug Lord) Subject: Re: SY-X24
Doug,
Thanks for the kind words about the 24.
Yes, we do anticipate that as the boat approaches planing speed, the upward component of the lift generated (even if the two boards are equally down) will aid in planing. This is the point of one of the inspirations for the curved keels (the ORMA tri's). We have not pressed this "feature" in the description of the design, in part because this lift will bring additional drag by definition. We have tried instead to keep the focus of people's attention on the combined solution of low transit draft, useable interior in a small boat, and (nearly) sportboat performance.
Keep an eye on our site for the latest developments of the 24 and more.
Cheers,
Doug Schickler
SYDE - Schickler Yacht Design and Engineering www.syd-e.com
Removing keelboat rudder..... epoxyman Boat Design 1 12-15-2006 12:02 AM
freeship assist please lazeyjack Software 7 07-22-2006 08:48 AM
Foil Assist: small or large monohulls Doug Lord Sailboats 7 12-22-2005 07:25 PM
Replacing chainplate structure - keelboat RickEdmonds Boat Design 3 07-22-2004 09:24 PM
Assist with prop choice -40-footer Guest Boat Design 1 06-23-2003 06:38 PM
