Old 06-03-2007, 10:56 AM
HomeyD5 HomeyD5 is offline
Rep: 10 Posts: 4
First design, need feedback
I'm trying to come up with a plan for a 10-meter aluminum bluewater sloop. Design touchstones are the Contessa 32 and Pacific Seacraft Crealock 34, with a pinch of Tahitiana thrown in. Here are the specs:
LOA: 33' . . . . . . Displ: 14,200 lbs
LWL: 27.6' . . . . Ballast: 6,250 lbs
Beam: 9.5' . . . . . Sail Area: 605 sq. ft.
BWL: 7.8'
Draft: 5.3'
Safety and a seakindly motion are prioritized above speed and interior volume. Here are some of my performance targets:
Capsize Ratio: 1.60 or less
STIX: 35 or better
Comfort factor: 37 or better
See the attached images for a rough concept I cranked out of Gregg Carlson's Hull Design program. Thoughs, critiques, and suggestions welcome.
First design, need feedback-gemini-.jpg  First design, need feedback-gemini-b.jpg  First design, need feedback-gemini-c.jpg
Old 06-03-2007, 12:07 PM
alan white's Avatar
Rep: 1168 Posts: 3,270
I would move bouyancy forward, increase rudder area, and straighten keel (a cutaway forward of the rudder would allow reduction of wetted area and make rudder more effective).
All this would make the boat more controllable when off the wind, and reduce weather helm when heeled.
Alan
Old 06-03-2007, 05:47 PM
Previous Member
Rep: 0 Posts: 0
i,m sorry I can see nothing good in this boat, losing loats of space aft too,
may I respectively suggest you down load freeship and have a go there, you did ask)
Old 06-04-2007, 06:34 AM
Tim B Tim B is offline
Rep: 763 Posts: 1,384
Just as an excercise take an existing yacht and try to replicate the shape in CAD. then play with it, making small adjustments.
You need to get used to playing with hull-shapes. Looking around hard-standing marinas is good fun and gives a better idea of the under-water sections.
Tim B.
Old 06-06-2007, 10:50 AM
Rep: 10 Posts: 4
Thanks for the feedback! Alan, I may need some clarification regarding your
suggestions; will get back to you once I've got FreeShip installed and am
up to speed on it. LazyJack, thanks for the good software tip and the
brutally honest opinion! BTW, FreeShip is now called DelftShip. Still
freeware, now up to version 3.1, can be downloaded here:
http://www.delftship.net
Old 06-06-2007, 06:04 PM
Previous Member
Rep: 0 Posts: 0
mate you had so many views but no comments!, freeship is different in that you can print things like the plate developements, which delft does not allow
Good luck, I want to see what you create, please, there will be heaps of people will help you in Free or delft
design feedback ieagreg1 Boat Design 27 12-04-2006 03:35 PM
Feedback on my first hull design VinceS Boat Design 86 08-08-2006 06:33 AM
My speedboat hull design!! need some feedback from you experts Dutcher Boat Design 22 06-19-2006 04:15 PM
Rowboat design feedback? John Larkin Boat Design 2 06-16-2006 04:14 AM
feedback on hull design mattias Boat Design 14 09-04-2003 11:41 PM
