Old 10-03-2007, 01:31 PM
MacFhearguis MacFhearguis is offline
Finding Used Hulls
I am toying with the Idea of building my own Sailboat.
I do not feel that I have the experience or know how to build the hull.
Does anyone have an Idea of where I can find used Sailboat hulls?
(of various lengths and design/ 50'+)
I feel very confident that I can build the boat from the hull up.
This will give me autonomy for cabin design and the like.
This is very appealing to me.
So any info about websites, locations, or dealers of used hulls
would be greatly appreciated.
Old 10-03-2007, 06:34 PM
alan white's Avatar
Rep: 590 Posts: 2,639
Hi Mac,
Outside of the many ads I've seen over the years for uncompleted boats, there are also the many smaller manufacturers who will provide you with a bare hull at a fraction of the cost of a completed boat.
Your best bet would be a start-up that never got completed, possibly by a known professional builder. If you find a home-built hull, have it surveyed by a surveyor who specializes in that type of hull material. It shouldn't be expensive if all is out in the open, far easier than a completed boat.
Alan
Old 10-06-2007, 06:11 PM
Gramp34 Gramp34 is offline
Rep: 10 Posts: 12
Given that you don't know where to find used sailboats, it sounds like you don't have much experience with sailing.
50+ feet is not a small project.
Have you spent much time sailing a boat this big? Will you have a crew available every time you want to take it out?
Bruce Roberts sells a kit for his VOYAGER 495 -- $85K for steel or $130K for aluminum -- and that just gets you precut parts for the hull and deck. (http://www.bruceroberts.com/public/H...ffers-kits.htm)
Roberts claims 530 man hours to build this hull, but do a reality check with people who've attempted it. For instance, http://www.thebigsailboatproject.com/sail1.htm gives a day by day account of two people building a Roberts 43. There's a lot of work involved.
Work (and cost) building a boat is proportional to the displacement, which increases with the third power of the length. A 50 foot boat will be about 50% more work than that 43.
And then there's the cost of parts. You can look up different parts in catalogs such as http://www.harkencompuspec.com/. Have a look at what manual primary winches cost for a 50' boat, let alone electric. Call a spar maker and ask what mast, boom and standing rigging will cost. You're in a size range where there is very little used equipment available, so you'll be stuck with buying a lot of it new.
Your best bet is to find people who've attempted such a project and either given up or died. Incomplete project boats sell for considerably less than the cost of the raw materials in them.
Add up the cost of everything you'll put into the boat, then check what used production boats this size sell for. Don't forget to consider what you'll be able to sell your boat for when you're done with it. Here's two just finished auctions on eBay for homebuilt boats:
Roberts 47 without rigging for $25K
Roberts 40 mostly complete for $35K
So, if you're thinking about building such a boat to save money, it probably isn't going to work. On the other hand if you want to build a boat because you want to build a boat, go for it. Just make sure to spend some time understanding what you're getting into.
Good luck!
Tim
Old 10-06-2007, 11:29 PM
Gilbert Gilbert is offline
Rep: 36 Posts: 472
To finish off a 50' sailboat could take one man eight years or so. Maybe more maybe less.
Old 10-07-2007, 12:30 AM
Rep: 489 Posts: 1,658
what allen said,,this is what I did,I purchased a north pacific (kit ) that was 40% done ,,fortunatly allmost all componants,were included,,ie rudder hardware stays exc,,even got marine ply ,all from 1967 era,,,barn kept ,even though ,,I still spend alott of time scrounging around and getting things ,for example,,I know I will need winches ,,got on ebay and got some ,,not too time consuming,but just another thing to do ,,it may behove you to look into the used ,,or damaged boat market,,,I got about 10,000 of my own dollars in this and another 20,000 of the previous owners money in it ,,i have some advantages,,but I think I could have been sailing 2 years ago instead of next year,,,,,,but on the other hand ,you couldnt pry this boat away from my cold dead fingers ,,,,longliner
Old 10-07-2007, 03:44 AM
Ramona's Avatar
Ramona Ramona is offline
Rep: 10 Posts: 70
Check out Ebay. Especially in the USA there are terrific buys to be had with older well known boats. Building boats is expensive and will always cost more than you can imagine.
There was a 30 foot Halverson yacht sold on the Australian Ebay a couple of weeks ago for just over $250. Fibreglass hull with a timber deck that needed a lot of work. Nice looking boat and I wish I had room for it. Probably 4 ton all up weight and with a ballast ratio of probably 50%, about $3000 worth of lead in the keel all for $250.
Old 10-07-2007, 09:36 AM
Kaptin-Jer's Avatar
Kaptin-Jer Kaptin-Jer is offline
Semi-Pro
Rep: 206 Posts: 523
I have done it both ways. (don't laugh) I built 3 boats from the ground up, and I am on my 2nd "restore". Re-storing a damaged or older hull is the way to go. You always end up gutting everything down to bare hull anyway, no matter what your original intentions were (Like "I will be able to reuse the wiring" - Ha!) To build a 50' hull - well it took me 3 years working on the weekends just to build the mold for a one-off 78' sloop. You need to shop US Auctions.com, ebay and just wait for another hurricane to come through, but from my experience it will save you about 2 years of work. Of course a 50' re-store will still take you at least 4 years. Long liner and Ramona are both right. and by the way I started with a small 27' boat and learned what to do. That took 3 years to finish. Now I'm working on a 38' sailboat, into my 3rd year and I am still looking at 2 more in front of me.
finding thrust scott steffe Powerboats 2 02-17-2007 09:37 AM
formula for finding waterline? Baldur Boat Design 13 06-17-2005 05:21 PM
Help finding a used Planimeter?? DCM Education 0 12-13-2004 11:09 AM
Hello and need help finding... Rattlesnake Gal Open Discussion 1 06-15-2004 10:35 AM
finding scholarship Archive Services & Employment 0 06-12-2001 05:04 AM
