Old 09-29-2005, 08:46 PM
delphidiemaker delphidiemaker is offline
fiberglass over molded foam core
I'm new to boating and sailing and have been given an old 12' rowing sailing dingy in need of hull repair/replacement. It appears to be a molded plastic interior in good shape and a molded plastic hull in terrible shape covering a molded foam core. Is it feasible to remove outer hull material and cover the foam core with fiberglass? If not any other suggestions? Thanks
Old 10-01-2005, 06:58 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
The outer hull and the deck are probably molded from fibreglass (glass-reinforced plastic); only in recent years have plain plastics been stiff enough for boats. So you've probably got a badly deteriorating fibreglass hull. The foam is probably poured in place afterwards. Often the fibreglass resins will dissolve these foams so repairing directly over the foam is not always feasible. It's hard to assess the condition of your craft; any photos?
Airex PVC core foam using ? signum Fiberglass and Composite Boat Building 10 02-01-2009 04:26 PM
Foam core Hotrod99 Fiberglass and Composite Boat Building 9 09-06-2005 02:24 PM
PVC Foam or Polypropelene Honeycomb sandwich core plimsoll_line Materials 7 03-20-2005 07:00 PM
PVC foam core thickness? Danielsan Fiberglass and Composite Boat Building 37 02-10-2005 01:45 PM
AIREX Foam core Brad Seger Materials 3 07-28-2004 01:36 PM
