Old 03-06-2008, 03:01 AM
ironmatar ironmatar is offline
Rep: 36 Posts: 33
a few questions
really i have a lot of questions answerd around here by the many threads
however iv come up against a couple of questions monohull/vs trimiran
and single or multi masted [3] cutter rigging and capable of 120,000-130,000# cargo
Old 03-06-2008, 11:56 AM
alan white's Avatar
Rep: 1168 Posts: 3,269
Any trimaran of that enormous size would require a budget that would build a far superior monohull. Out and out speed isn't average speed----- and the monohull is probably faster on average. Yet it would cost much less to build and own.
As far as rigs go, a multi-mast rig is going to be more reliable and handy than a single mast rig, though a single mast would be faster, as it catches a faster wind.
Alan
Old 03-06-2008, 01:02 PM
Rep: 36 Posts: 33
well i dident consider cost really as the materials would be the same either way.
in this case the cargo space dictates to the base boat length and width somewhat 15x55x9 footprint for 2 truckloads<approx>cargo.
the idea to use a tri came from the apathy i have for hanging some great mucking bub keel everyone is hanging on monohulls these days some 10-15' below the waterline just begging to be smashed/ripped off and or flat tangeld up in submerged junk
Old 03-06-2008, 02:37 PM
alan white's Avatar
No worries regarding submerged objects if the ship is big enough to carry 130k lbs cargo. At first I thought you meant 13k-14k of cargo. But if the mono depth is to be 10-15 ft, then maybe you do mean 130k-140k.
Confused.
Old 03-07-2008, 05:24 AM
Rep: 36 Posts: 33
well base masters lic is 100T 200k steel boat 70-80 maby 90k /carrying cap 110-130k and a base waterline hull length 5-1 19x95' expected draft 9-13' 3 decks lower deck cargo deck and topdeck w aft pilothouse w cutter rigging.
silica concrete wash coating for steel and doug fir decking /interior steyr monoblock desils and levi surface htdrive and 360 deg thrusters for and aft..
a lot of people have do nothing boats that are unable to make their owners any return. big boats other than racers should be functional
i relly figured a monohull was best but after reading the latest about the idec wave pericing tri going circumnav in 57 days i thought id ask around here about it.
yes it hauls but id like it to haul as fast as reasonable possabale. id like to be able to get 12-15 knots out of it.
Old 03-07-2008, 12:06 PM
alan white's Avatar
Others would know more than me. I would assume any boat carrying a reasonable cargo would be fastest as a monohull. Sailing, you wouldn't get a multi of any cargo-carrying capacity to take advantage of wave-piercing. All that hull skin, designed to go fast, would therefore just be more of a dog at displacement speeds.
The 100 ft mono should approach 14 kts under optimum conditions, but under poor conditions like 5 kts breeze it will still move along nicely, leaving an equal displacement (and length) multi far behind.
In a sailing cargo boat, minimum wetted surface is what you want, I would think.
Alan
Old 03-09-2008, 12:33 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2006 Posts: 1,638
A pair of vee bottom hulls in a catamaran config. will provide stability without ballast. Shallow draft too. Rig could be in one or both hulls.
Old 03-09-2008, 03:07 PM
brian eiland's Avatar
Rep: 1503 Posts: 2,648
GreenPeace Motorsail vessel
How about something along these lines?
New Greenpeace Motorsail Vessel
http://boatdesign.net/forums/showpos...8&postcount=52
RunningTideYachts.com
Distinctive Expedition Yachts
Old 03-15-2008, 08:15 AM
Rep: 36 Posts: 33
i really prefer a single mast or 3 masts its a matter of numerology and the rightness of a thing
given what iv been reading about aft mast rigs why tilt the mast at all brian why not use a forward mounted boom of desired length and rig it so it it holds the top spread the same distance apart at the desired point in relation to raking the entire mast forward and elimitaing rigging problems by tilting the entire mast?
Old 03-15-2008, 10:45 AM
Tad's Avatar
Tad Tad is offline
Yacht Designer
ironmater,
If you would like clear and thoughtful answers to your questions, you really need to take time to state your ideas clearly so that they can be understood by others. I realize punctuation and capitalization are not cool, but the above posting is pure gibberish to me.
If you wish to be taken seriously please revise the above.
Old 03-17-2008, 09:16 AM
water addict water addict is offline
Naval Architect
Rep: 73 Posts: 311
any significant cargo weight, and a monohull is better.
Multis are only good if they can be lightweight, or if you have some stability driven issue. If carrying capacity is a concern, multihull will be pathetically slow compared to a monohull.
Old 03-17-2008, 11:30 AM
Tad's Avatar
Tad Tad is offline
Yacht Designer
[quote=water addict;191450] or if you have some stability driven issue. [quote]
That was the original request......how to eliminate the ballast keel.
The unballasted monohull option would be something along the lines of a scow schooner, some big ones were 85' by 36'. That’s not exactly a speed boat either.
Personally I believe draft could or should be a large issue for small freighters. With shallow draft or drying out ability, plus the ability to self load/unload, a small freighter can directly service areas ignored by larger vessels.
The waterline will have to be 80' to manage 12 knots economically. Standard containers are roughly 8' wide. Leaving aside the whole tonnage issue. (yes, I know that's not possible IRL) Will two hulls approximately 80' by 10' with a total beam of say 30', be faster, slower, or otherwise, than a barge 80' by 34'?
I believe a multihull might offer some other advantages as well as shallow draft, beached stability would be one, the possibility of the bow ramp for driving vehicles directly aboard, large deck area to deal with light cargos, etc.
Old 03-18-2008, 07:58 AM
Rep: 36 Posts: 33
i had envisioned a longship hull shape with the keel doubleing as the weight instead of having a great long fin or pole with bulb on it and a big cutter staysail rigging on 3 masts w a aft pilothouse. The folding crane tucks away in a compartment just aft of the second mast and the main cargo hatch is between the foot of the pilothouse and the crane compartment on deck. i specfied a 5x1 boat at the waterline in order to get some better preformance out of it 19x95' and probably 27x135 overall <bowsprit/aft jib spar>
but perhaps a diffrent hull shape might be better.
Old 03-18-2008, 12:01 PM
Naval Architect
Rep: 73 Posts: 311
Tad,
I didn't see that ballast elimination was the crux of the original post- did I miss it?
ironmatar,
Much depends on the cargo. What do you envision the route and cargo to be? Definition of some basics is really important.
Old 03-18-2008, 12:34 PM
Rep: 36 Posts: 33
cargo anything you want to load in it
route where ever you want to take it.
Various Questions KI4NCW Metal Boat Building 30 02-02-2007 07:30 PM
Some questions. fcfc Option One 10 11-05-2006 05:39 PM
Greetings and a couple of questions adventurer Motorsailers 1 09-29-2006 08:54 AM
General questions sci teach Boat Design 3 08-16-2006 07:53 PM
questions Redsky Wooden Boat Building and Restoration 13 07-07-2006 02:00 PM
