| Favorite rough weather technique I heave-to routinely. That is, back up the jib and set the tiller to leeward (or the rudder to windward). It is easy, fast and settles the boat into a relatively easy motion. It makes it safer to, for example, take a reef down.
__________________ Gonzo |
| Do you mean a reefer furling main? I mean how do you slide the main down the track when the slides are loaded in heavy winds? Before I wised up and bought a power boat my 63 foot sloop needed to shake the main down by holding her into the wind. |
| I heave-to with any kind of reefing system or with the main doused. The jib is doing the work.
| For now, at the first sign of bad weather I goose the throttle and aim for shelter at 20-30 mph. This is pretty much the best storm tactic a small runabout has to offer. On the occasions where I have been caught in significant seas, modulating the throttle to maintain steering control and stay on the backs of the waves (if running) or aim for the destructive interference nodes (if beating) works very well, but requires a lot of concentration. (On several occasions, I've run a 5-metre boat into 2-metre seas this way, and ended up with slightly spray-dampened crew but a dry bilge.) Of course, this is in small, fast powerboats; tactics will differ greatly when you go from 20 to 500 lb/hp and add a deck, keel, etc....
__________________ Matt Marsh M. B. Marsh Design The Marsh Fleet: Small-craft cruising on the waterways of Ontario and beyond |
| Modulating the throttle is crucial. I remember my sister cutting the throttle suddenly while surfing a 18' runabout and getting pooped. She was really embarassed to sink her friend's boat.
| My Favorite heavy wx tech is to stand on chicken point in Winchestor bay Oregon and watch other people trying to get across the bar. ![]() K9 |
| Reminiscent of the surest cure for Mal De Mer! (Take a nap under an apple tree) |
| gonzo you never got caught by the so called 'bora' off the coast of croatia... if you are sailing there and do not see the signs in time or ingnore them or are not able to read them, winds with forces 9 and higher might hit you within less than an hour... leaving you trapped in the middle of a lot of stoney and ugly islands... you definitely do not heave-to there... what i am trying to bring across: heavy weather strategies are very much dependent on the situation and location you are encountering it... you got a lot of water around you - you actually could do as fits you... you are close to land - reach open water as fast as possible... even if this means beating upwind for hours and knocking the crew about on the ship... generally i am trying to get out of the weather with all speed and sails up the ship can bear and on the safest yet fastest course... and i have to confess - i like riding a storm very much! ![]() |
| I learned to sail in the Plata river. There is an average of nine hurricane force winds a year, plus several gales. The "Pampero" is similar to that. The wind dies down, the temperature drops twenty or more degrees and within ten minutes the front arrives with hurricane force.
| so you know how fast a front with dangerous windforces can hit you... but it was not the point of my posting... any weathering strategy capable of getting the ship and crew through the rough times unharmed is dependend on the circumstances you are facing... different circumstances - different strategy a good skipper should be confident with any strategy there is... but to be honest - i like to sail it out with a course having the wind on the beam to aftship depending on the seaway and the traveldirection of the waves... and with enough water ahead of me.... you see - there have to be a lot of conditions met before i can do what i like most... ![]() |
| In extreme cases my favorite is to panic, run in circles and scream. It is what I read in most "disaster" sailing stories ![]()
| hehe... unfortunately this is the case with most skippers... ![]() |
| I never remember to heave to or do anything sensible when the circumstances call for a clear thinking. I always just fight it out- half under water with gear flogging about.. and tell the stories in the bar afterward. |
I'm a JGOWI man myself (Just Get On With It) Hm: this might need a whole new thread ...
| Favorite stupid | gonzo | Open Discussion: All Things Boats & Boating | 125 | 02-20-2011 06:11 PM |
| My favorite youtube video..... | oscarvan | Multihulls | 4 | 06-15-2009 08:23 AM |
| Favorite Filler Recipes, Please | rturbett | Fiberglass and Composite Boat Building | 16 | 06-02-2007 10:28 AM |
| What is your favorite book on boatbuilding? | Boreas | Wooden Boat Building and Restoration | 8 | 03-13-2007 05:57 AM |
| favorite lines? | stevel | Powerboats | 0 | 10-14-2004 04:11 PM |
