Old 08-31-2004, 12:22 PM
SeaDrive SeaDrive is offline
Rep: 15 Posts: 223
Originally Posted by Slowmo
[b]
Let's focus on main + jib only.
What does the designs tell you?
29'er (sail 12,5m2)
Spec: http://www.wet-windy.co.uk/2150_29er.html
http://www.29er.com/4027,275,1-0.html
international 420 (13m2)
http://www.420sweden.se/Assets/Pictures/index.htm
http://www.420sailing.org.uk/index.p...ba07543f210c30
international 505 (14m2)
http://www.irbs.com/directory/Dmoz/Sailing/Class_Sites/
It was my intention to find a flat bottom (2 or 3 chines) plywood sharpie, but so far I didn't find any typical example with 12-14m2 sail.
Perhaps the Windmill: http://www.windmillclass.org/faq.html
The question needs some focus. We have dinghies mentioned, then we are worrying about the southern ocean.
For a dinghy comparision, study the history of a development class such as the Moth or International 14.
For keelboats, there were the square meter classes.
Conditions and crew make a big difference. I read that the Cal 40 was slower around the buoys than later Cals, but faster to Hawaii because it was easier to helm. That made a difference in a long race, but not in a short one.
Old 08-31-2004, 04:47 PM
Slowmo Slowmo is offline
Registered
Rep: 10 Posts: 38
Originally Posted by Ilan Voyager
A part the odd discussion about the fastest etc
A hard chine skiff running pretty well is the old Fireball. Designed for plywood. Planning like crazy. Look for plans in the internet. It's an international class with a lot of gadgets hardware on. Do not be fooled use the hull and put the rigging you need. It may fulfill your requirements. .../
Fireball seemed a little bit odd. To include the Windmill wich looks more convensional...
http://www.fireball-international.co...d_maintain.php
First it says in the windmill presentation that it is overpowered with 100sq' wich is around 10m2. The fireball is also fast.
What would be the first (1) design change you would make to those dinghies to make them:
A) more safe /steady?
B) A + carry extra load (~300lbs)
Old 09-01-2004, 11:06 AM
Rep: 15 Posts: 223
I'm not sure where you get that. In the third paragraph, it refers to the sail area as 'moderate.' http://www.windmillclass.org/faq.html
Old 09-01-2004, 12:00 PM
ErikG's Avatar
ErikG ErikG is offline
Rep: 344 Posts: 397
Hej slomo igen...
Jag gissar att slomo här o morgan där är samma person.
I think that you need to define what it is that you are really looking for.
If you are the person I think you are you first said that you wanted a rowboat that can sail, now you are comparing your ideal mystery boat with planing dinghys.
You have to focus on what you want and why, and go from there.
When you seriously start learning about a subject like boat design you will realize that its quite a complex subject, and there aren't as many straight and simple answers as you would like.
A fast planing dingy will not make a good platform for a rowboat or beeing powered w an outboard. It is not meant o carry large loads either.
You cant build a fast, light, safe, heavy, loadcarrying dinghy cheaply that has a small sailarea. Its just not possible. You have to FOCUS on what you want and why and how to achieve it.
Please forgive me if I'm wrong in assuming that you and morgan.o is the same.
Old 09-06-2004, 09:17 AM
Registered
Rep: 10 Posts: 38
No, there is no reason why I should excuse you.
It's quite clear that your mission isn't of the kind sort and that you try to behave according to netiquette while your crusade still have the lowest possible intentions.
Netiquette is built on respect, und you don't accept that.
Actually it's a disgrace that your mess havn't been erased yet.
Old 09-06-2004, 10:36 AM
sorenfdk sorenfdk is offline
Yacht Designer
Rep: 394 Posts: 508
What on earth is the matter with you? Erik made a mistake in identifying you, but so what? He even asked for your forgiveness if he was wrong... But perhaps forgiveness isn't part of your kind of netiquette?
BTW: He was right in everything else he said!
Sail Loading on Rig, Rig Loading on Vessel brian eiland Sailboats 93 02-23-2011 07:19 PM
Anyone familiar with Powerfoil sails? Mark Neill Sailboats 12 12-17-2008 10:07 PM
Loose footed mains Polarity Sailboats 65 09-14-2007 04:37 PM
The Concept Catamaran Project Duane Mc Boat Design 63 08-14-2005 07:34 PM
Why sail over power? Why power over sail? mackid068 Boat Design 19 04-12-2005 07:54 AM
