Old 10-29-2010, 07:35 AM
3333feet 3333feet is offline
Rep: 10 Posts: 10
ezelfin
please analiyze the hull for me
Design hydrostatics report.
Designer
Created by
Comment
Filename Ezelfin.fbm
Design length 13.721 (m) Midship location 6.861 (m)
Length over all 13.522 (m) Relative water density 1.025
Design beam 4.257 (m) Mean shell thickness 0.0000 (m)
Maximum beam 4.282 (m) Appendage coefficient 1.0000
Design draft 0.554 (m)
Volume properties Waterplane properties
Moulded volume 8.787 (m^3) Length on waterline 12.472 (m)
Total displaced volume 8.787 (m^3) Beam on waterline 3.282 (m)
Displacement 9.007 (tonnes) Entrance angle 8.732 (Degr.)
Block coefficient 0.2713 Waterplane area 28.232 (m^2)
Prismatic coefficient 0.5148 Waterplane coefficient 0.4833
Vert. prismatic coefficient 0.5613 Waterplane center of floatation 6.160 (m)
Wetted surface area 31.052 (m^2) Transverse moment of inertia 18.071 (m^4)
Longitudinal center of buoyancy 6.544 (m) Longitudinal moment of inertia 227.84 (m^4)
Longitudinal center of buoyancy -2.538 %
Vertical center of buoyancy 0.361 (m)
Midship properties Initial stability
Midship section area 1.244 (m^2) Transverse metacentric height 2.417 (m)
Midship coefficient 0.5270 Longitudinal metacentric height 26.290 (m)
Lateral plane
Lateral area 5.129 (m^2)
Longitudinal center of effort 7.231 (m)
Vertical center of effort 0.322 (m)
The following layer properties are calculated for both sides of the ship Layer Area Thickness Weight VCG LCG TCG
(m^2) (tonnes) (m) (m) (m)
Layer 0 85.632 0.000 0.000 0.997 6.652 0.000 (CL)
Sectional areas
Location Area Location Area Location Area Location Area Location Area
(m) (m^2) (m) (m^2) (m) (m^2) (m) (m^2) (m) (m^2)
0.686 0.000 3.430 0.801 6.175 1.248 8.919 0.946 11.663 0.179
1.372 0.133 4.116 0.976 6.861 1.244 9.605 0.770 12.349 0.055
2.058 0.356 4.802 1.111 7.547 1.190 10.291 0.570 13.035 0.002
2.744 0.588 5.489 1.203 8.233 1.089 10.977 0.362
Old 10-29-2010, 07:41 AM
Rep: 10 Posts: 10
sorry
Old 10-29-2010, 07:44 AM
Rep: 10 Posts: 10
other
Old 10-29-2010, 08:08 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
