Old 04-21-2008, 02:49 PM
Pylasteki Pylasteki is offline
Rep: 35 Posts: 52
Extending bow sprit?
Hi guys,
I'm curious about these extending bow sprits that are used on some of the new racing boats.
I'd like to take my spinnaker pole, and build some chocks for it on deck with a line running to a bow eye, and be able put a drifter waaaay out front in the very light winds.
Anyone seen something like that?
Thanks,
Zach
Old 04-21-2008, 04:49 PM
alan white's Avatar
Rep: 1168 Posts: 3,270
Originally Posted by Pylasteki View Post
Hi guys,
Thanks,
Zach
Yes, the sprits are commonly epoxy/carbon fiber, easy to build using a styrene foam core that can be melted out using acetone afterwards (or you could leave it in----- now who's gonna come up with one with a bugle end that the sail can be sucked right into?). You need a mounting plan, meaning two points, one at the bow and one inboard a few feet. Those sleeves must be bonded strongly to the boat. No whisker stays are required though you might have them for security.
Aluminum would also work, though not as strong per weight (but ultra simple).
Alan
Old 04-21-2008, 08:43 PM
Meanz Beanz Meanz Beanz is offline
Boom Doom Gloom Boom
Rep: 585 Posts: 2,286
I have seen Tornados Cats that have this setup, half the pole is a pipe large enough to hold the kite.
Old 04-21-2008, 08:45 PM
Like this but all carbon and a bit slicker looking.
Old 04-21-2008, 11:31 PM
alan white's Avatar
It's as if they could see into the future when I invented it!
Old 04-22-2008, 01:47 PM
Rep: 35 Posts: 52
Boy do I ever know that feeling.
Looks cool!
Anyone have a picture of the deck chocks? At the moment I'm thinking a block of wood and a hole saw of the proper diameter and then cutting them in half.
Old 04-22-2008, 05:48 PM
That would be an easy way and quick. If weight is an issue I would be tempted to laminate them up in grp or carbon epoxy.
Old 04-22-2008, 07:08 PM
Paul B Paul B is offline
Rep: 6 Posts: 1,696
The chocks are under a HUGE load, with the forward one trying to pull up off the deck and shear to the side at the same time. The aft one is being driven into the deck and shearing sideways as well. A pc of wood is not going to do it.
I did this setup on my boat last year. I machined the chocks from 6061 and lined them with teflon tape to make the carbon pole slide easily and not react with the aluminum.
I would not use an aluminum pole if you plan to have much of an extension. Carbon is the only way to go.
Old 04-22-2008, 07:23 PM
Not sure he was talking about that kind of chock, "cutting them in half" suggests a std deck pole chock.
Old 04-22-2008, 09:49 PM
Rep: 35 Posts: 52
I'm thinking a laminated hunk of marine ply about 6 inches long (Drill one side, flip and drill the other) and cut it in half, then mounting a cleat on each side using a piece of vectran or other low stretch cord to lash it down. Spent a little time pondering a cup glassed into the front of the cabintop for the aft end, but the extension would be short for the deck space. If I go that route I'll spend some time to design a chock that'll dual purpose an anchor roller.
I'd prefer it pop loose if I stuff the bow in a wave rather than rip my deck in two, and be quick to convert from whisper pole to bow sprit and back to keep from wrapping anything up at anchor, and save on dockage for loa.
That carbon pole and aluminum chock look cool! How quick does it unbutton? Assuming it does, with the height of the bow light.
Old 04-23-2008, 07:57 AM
kenJ kenJ is offline
Rep: 56 Posts: 323
Sprits
A link from Sailingworld.
http://www.sailingworld.com/sailing-...000008058.html
Old 04-25-2008, 05:43 PM
Rep: 35 Posts: 52
Very cool... Pre-made kits.
Little bit steep, so I think I'll end up making my own.
Help extending? Matt.D Boatbuilding 47 12-14-2007 10:22 AM
Planing bow hull and getting over the bow wave hump kach22i Boat Design 2 04-03-2007 04:51 PM
The buoyant bow and bow steering in heavy weather kach22i Boat Design 8 01-06-2007 06:13 AM
Big Bow Sprit Water Tightness - Methods Scott Carter Wooden Boat Building and Restoration 4 10-29-2006 05:13 PM
olson 30 sprit antoine1 Boat Design 1 10-04-2004 08:42 PM
