| Explain Sailboat Specifications I wanted an explanation of Sailboat specifications. I understand LOD, LWL, and headroom etc... I would like an explanation of Beam. How is the Beam measurment defined. |
| Beam is the maximum breadth (width) of a boat. Eric
| Well, theoretically you could have significant variations between beam on waterline, beam on deck, and beam between rubbing strakes. |
If you want specifics you modify beam or length with words like waterline (waterline beam, waterline length). Is there a real question here? Common usage is maximum width of the hull. (not including fenders, rubrails etc.)
__________________ Proud supporter of The Far Kurnell Cat Racing Team I have not failed. I've just found 10,000 ways that won't work. - Thomas A. Edison |
| ITTC symbols sailboat dimensions and design ratios ![]() LOA = Length Overall - overall tip-to-tip length of the boat LWL = Length Waterline - length of waterline of the boat DWL = Design Waterline -theoretical waterline length of boat as opposed to LWL, which is actual waterline length BMX = Beam Maximum - width of the boat at the widest point BWL = Beam Waterline - widest beam of boat at the waterline I = Height of the foretriangle measured from the top of the highest sheave to the sheerline I2 = Height of staysail halyard above deck J = Base of the foretriangle measured from the front of the mast to the intersection of the forestay and deck J2 = Base of staysail triangle P = Luff length of the mainsail E = Foot length of the mainsail LP = Shortest distance from headstay to the clew of the jib (from Harken site)
| Travelift specifications | gonzo | Boatbuilding | 3 | 12-28-2004 06:29 PM |
| specifications for sail textile | amitk | Materials | 1 | 09-07-2004 04:19 AM |
| epoxy specifications | mselle | Materials | 5 | 08-25-2004 03:27 AM |
| boat specifications/ plans | jmills | Boat Design | 0 | 09-08-2003 08:57 PM |
| Can Someone explain Electolysis please? | Matthew | Boat Design | 4 | 09-23-2002 11:07 AM |
