Old 06-20-2005, 08:58 AM
jonny kennedy jonny kennedy is offline
Rep: 10 Posts: 3
evolution 26
We bought a evolution 26 designed by Julian Everitt. i have just started racing this boat in Lough Neagh Sailing club and am trying to get information on this boat.
Any info will be greatfully accepted.
thanks
Old 07-09-2005, 07:36 PM
asathor's Avatar
asathor asathor is offline
Rep: 10 Posts: 154
http://www.yachtworld.com/core/listi...1&photo=1&url= here another "evolution"
May the wind blow briskly in your sails!
Old 07-15-2005, 08:02 PM
CT 249 CT 249 is offline
Rep: 286 Posts: 1,140
I don't know much more than that the Evolution was designed as a quarter ton (IIRC) racer/cruiser. I think only a few were built. One, "Absolution", was mis-rated (measurer's mistake) and dominated Solent racing about '81, winning against the flat-out racing quarters. She actually performed quite well even when allowing for the incorrect rating IIRC. If you have access to a library of Seahorse mags back to about '81 you'll find a season summary from Absolution's skipper in the "Coastal round up" they did each year. There was also a report in Seahorse about the measurement error and that may have some comments about the boat, from memory.
EDIT; I happened to find my old Seahorse binders. Absolution won Solent Points in her class for two years, so both '80 and '81 Seahorses had reports (about 600+ words) from the skipper. He had some quite detailed info about sheeting angles, sail selection etc BUT (big "but") apparently Absolution was modified from the standard masthead rig to a fractional rig and therefore all that stuff would be of little use to you. If yours is a fractional, post and I may be able to copy out some of his info.
Old 07-22-2005, 08:02 AM
Rep: 10 Posts: 3
mine is a mast head rig and it weighs just over 2 ton
Old 07-27-2005, 05:03 AM
grumpy_gorilla grumpy_gorilla is offline
Evolution 26
I have owned an Evolution 26 ("GrumpyGorilla" ) for 10years and race it on the Solent, normally Thursday evening racing around the cans at Royal Lymington Yacht Club. They were originally built at Christchurch (5 miles away) . We have 2 fractional rig 26's ( including "Absolution") ,2 masthead 26's and 1 fractional Evolution 25. The 25 has the same hull as the 26 but a different coachroof allowing more headroom down below. There were various combinations of rigs ,normal masthead, fractional ,whereby the mast was moved 8inches forward of the original step , and an odd-ball fractional rig that was 30inches taller than the standard fractional rig. Apparently , this was popular in places like Poole harbour ,where quite a number of them can be found, where the wind is more "flukey" because of the number is islands. "Absolution" still outstrips any of the other Evolutions and often bigger boats in other classes.
I think it was 2000 when she came 18th overall in the "Round the Island Race", not bad out of 1800 boats racing.
Christchurch has a larger fleet, as does Poole, and they often have match racing against each other. We are trying to get Lymington involved in this as well.
Normally, the fractional rigs go better upwind but the masthead, with bigger spinnakers, reverse the trend downwind.
I have got the original Sales "blurb" and will copy it for you. Also Practical Boat Owner did a report November 1981 P55 by Rodger Witt ( you can buy copies from PBO for £3.50) - Interesting reading.
Anything specific you need to know , I'll try and answer.
regards
Old 07-31-2005, 04:56 PM
Rep: 10 Posts: 3
ive seen the pbo report.
ours is goes well up wind and point very well.
we are not used to masthead rigging and our looking to find out about setting the rigging in terms of rake in the mast. is there any way you could put me in touch with an owner of a masthead 26
thanks
design of a fast 27 catamaran SAILFASTtigre Multihulls 26 06-06-2006 04:43 AM
Mac 26 "Blam" Thread mackid068 Sailboats 67 07-28-2005 02:12 PM
Info about rigging terminals evolution Rigman Sailboats 8 02-12-2005 10:35 AM
thunderbird 26 or 32 scottscotland Boatbuilding 2 02-09-2004 11:03 AM
26' Hydrasports doesn't handle 2-3' seas Archive Powerboats 2 06-12-2001 04:35 AM
