  #61
Old 03-09-2012, 06:12 PM
upchurchmr upchurchmr is offline
Rep: 316 Posts: 894
There was one in this Challange - a "modified E-scow", (already scalped and meatstick) don't know about earlier. That would scare me much worse than a Tornado. I wonder how it was modified?
  #62
Old 03-09-2012, 06:22 PM
hoytedow hoytedow is offline
Rep: 2142 Posts: 4,225
I think you mean this one.
everglades challenge sailboat-100_3147.jpg  everglades challenge sailboat-100_3158.jpg
Hoyt
The TITANIC sank because it had a hole in it(still does). Submarine Tom
You just can't put too much info on your patterns. DGreenwood
  #63
Old 03-09-2012, 06:23 PM
spidennis's Avatar
spidennis spidennis is offline
Rep: 124 Posts: 502
Originally Posted by upchurchmr View Post
A windsurfer sounds like a great new concept. Custom made (bigger) board with supplies capacity (minimal size) for the guy who does marathons or triathlons. There should be some kind of a stabilized harness to take most of the weight off the legs. This would really be tough, almost as tough as a PD Racer with a better chance of finishing well.
Calling all tough guys with something to prove!!!!
Spidennis - don't get so negative, you could portage much more easily.
sorry about the tone ....
I've done a lot of windsurfing in the past.
hooked into the harness for 3 hundred miles? Ug!
there's also the issue of reefing.
still no one has come up with a good plan for that.
I'd like to use windsurfing sails on my boat but I got that same problem.
I paddled the coast of texas a couple of years back,
there's very few in that club .......
but the one to take the cake is the married couple that used a paddle board,
and I'm not talking SUPs either ...
now that's hard core!
but they self supplied each other along the way.
There's a guy paddling in Class 2, now that's tough!
he's presently leading the UFC, but not for long ......
  #64
Old 03-09-2012, 06:24 PM
Rep: 316 Posts: 894
One of these EC threads commented that the reason for a lots of DNF's this years was the large number of DNS at the start.
19 Boats still participating or finished
60 Boats entered
5 Boats DNS at the start.
So 36 boats have DNF'd during the race.
Spidennis, nothing taken from your tone. There just are a lot of boats I would not want to try, but somebody will get a "good" idea to make it possible and will try. I'd like to see what that Idea would be since I haven't got a clue!
  #65
Old 03-09-2012, 06:28 PM
I tell you the wind was fierce and persistent that morning and straight out of the south. I saw one guy wear himself out for over 2 hours just trying to get past the surf line. He never made it and got bloodied in the attempt. You can see the halyard bowed on the scow in the photo above and it almost never went slack from the wind letting off.
Hoyt
  #66
Old 03-09-2012, 06:32 PM
Rep: 316 Posts: 894
That's amazing with such minimal waves. I wondered if the picture was the previous day or something.
If you couldn't sail to windward in those conditions there needs to be some serious re-evaluation of the desirable qualities in an EC boat.
  #67
Old 03-09-2012, 06:36 PM
The boat I previously mentioned that couldn't make it had a large profile above the water line and the solo skipper couldn't row it out. Then he got pushed back into the sand and his rudder pintles came out of the gudgeons. By then he was exhausted and bloody. He was game to keep trying but Chief pulled the plug. The ones that could make it out that day did it by rowing from shallow water until they got to a point where they could raise sail and tack without being driven back onto the beach.
Hoyt
  #68
Old 03-09-2012, 07:25 PM
Doug Lord's Avatar
Flight Ready
Rep: 1101 Posts: 7,421
Did the scow guy ever get going or was that the one the Chief pulled the plug on? The scow looks remarkably small....
yes, it is a Revolution
  #69
Old 03-09-2012, 07:29 PM
The Chief pulled the plug on a different boat. It was shorter, stouter and had a higher freeboard. It was a sloop rigged little cruiser about 15' long.
Hoyt
  #70
Old 03-09-2012, 07:34 PM
Rep: 316 Posts: 894
Doug,
An E-scow is 38' long. The reason I would be scared to sail one with two people is the large size of the boat and sail, and the tendency to slam in waves. It really is a flat water boat.
  #71
Old 03-09-2012, 07:40 PM
I agree entirely, but what do I know? That hull posted above looked like it would plane but more in the sense of a carpenter's plane, shaving off the tops of the waves. It didn't appear to be 38' long though. I guess that is not the same boat.
Hoyt
  #72
Old 03-09-2012, 07:42 PM
Doug Lord's Avatar
Flight Ready
Doug,
Up, E-scow is 28' long and weighs 900lb-crewed on one as a kid. "A" scow is 38' LOA. I've been on an E-scow in 3-4' waves in Pensacola Bay-heeled it cuts right thru waves. I wouldn't sail a normal scow- I'd either modify it with DSS or build from scratch with DSS. Adds phenominal RM, no weight and draws nothing..
Could make the perfect Challenge race boat....
They're sailed at an angle of heel at all times except downwind in a lot of breeze: click on image
everglades challenge sailboat-e-scow-weather.jpg  everglades challenge sailboat-e-scow-weather-2.jpg  everglades challenge sailboat-e-scow-spin.jpg
  #73
Old 03-09-2012, 07:47 PM
28'. That fits.
Hoyt
  #74
Old 03-09-2012, 08:12 PM
Rep: 316 Posts: 894
3 or 2 what's 10 feet between friends?
I once was sailing a Tornado in 30 -40 knot winds with a novice friend (no jib) and the only other boat was an E-scow with 8 to 10 people on the rail. It was all great fun until we passed them going to weather at twice their speed when they quit and went in. I always felt a little bad about that.
  #75
Old 03-09-2012, 08:17 PM
Doug Lord's Avatar
Flight Ready
E-scow and 20' Shark catamaran were always neck and neck in the old days.
I think a scow has a lot of potential with updated tech.
Everglades Challenge 2011 dstgean Multihulls 11 03-08-2011 02:29 PM
Everglades Challenge - heaviest solo boat? gardnerpomper Boat Design 14 02-27-2011 07:05 PM
Everglades Challenge 2010 Doug Lord Multihulls 11 03-09-2010 03:58 PM
Smyth goes after Everglades Challenge... Again Chris Ostlind Multihulls 12 08-14-2009 12:37 PM
Tornado Team Takes Everglades Challenge Chris Ostlind Multihulls 22 03-09-2008 08:37 PM
