Old 08-11-2010, 01:44 AM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
Pauls, do yourself a favour and get the following book; Sailing Rigs and Spars by Matthew Sheahan.
On pages 16 & 17 (and other) is about everything you need to know to calculate the scantlings using Euler's formula with different load conditions, panels, inertia etc.
Just one little error on page 18 with wrong value used in a formula. The book also let you calculate stays and shrouds with lots of data and graphs all over.
I can scan these pages and post them by might have some flack with copyright issues, unless everyone will forgive me for that and I might just attach them for you
Wynand
A scatterling of Africa
Old 08-11-2010, 04:28 AM
Rep: 1729 Posts: 2,464
You can scan a few pages for educational purposes. No problem, educate us
Mike Johns.
Old 08-11-2010, 05:54 AM
Wynand N's Avatar
Rather let the scans educate all of us, Im just a humble boilermaker
Pauls, you should find what you need from some of these few pages, if not, I'll make another few scans for educational purposes
Pardon the notes on one of the pages made by me...
Euler Factors for Mast Design-1.jpg  Euler Factors for Mast Design-2.jpg  Euler Factors for Mast Design-3.jpg
Euler Factors for Mast Design-4.jpg  Euler Factors for Mast Design-5.jpg  Euler Factors for Mast Design-6.jpg
Wynand
Old 08-22-2010, 04:04 PM
idkfa idkfa is offline
Rep: 66 Posts: 232
If a composite mast is made pre-bent, say about 3-4 diameters worth. Does it still obey Euler or approx how much deivation (diameters) before it no longer does?
Columns can take lots of load, so long as they remain in column, so how is pre-bend treated.
Old 08-22-2010, 06:51 PM
Rep: 66 Posts: 232
If we simplify the mast to be straight sections; deck - spreaders and spreaders - shrouds. (see diag) Then my question is at what angle does the column fail like a column (Euler) and not a joint?
Old 08-23-2010, 04:05 AM
latestarter latestarter is offline
Rep: 46 Posts: 72
The following is based on my knowledge of structures, I have never calculated a mast.
Euler still applies, you just modify for the extra effects.
When a compressive force is applied to a column that is not straight it gives rise to a bending moment calculated by the compressive force times the eccentricity, which is the offset relative to the straight line joining the top and bottom of the column. (in your term pre-bend)
The column is calculated by combining all the applied forces.
Adding up all the compressive forces and dividing by the cross sectional area and the permissible compressive stress. Say A
If the column is not symmetrical the total bending moments in the xx and yy axes are divided by their respective section moduli and by their permissible bending stresses giving results, say B and C.
Provided A + B + C is less than 1 it is considered to have passed.
As the slenderness ratio of the column increases, the allowable compressive and bending stresses decrease.
Old 08-23-2010, 10:32 AM
Rep: 46 Posts: 72
My previous post was based on designing buildings where deflections are kept small.
In the case of masts where the shape of the mast can be temporarily altered to adjust the shape of the sails I think the same principles would apply, but as the mast curves the eccentricity will alter making the analysis more difficult.
Old 08-23-2010, 04:11 PM
Rep: 66 Posts: 232
thanks latestarter, I'll make an attempt and post a bit later, found the following using your input.
http://www.efunda.com/formulae/solid.../eccentric.cfm
must confess I started the mould today! all a bit backwards but I have checked my design against similar ones, it just that I have a huge bend too (half length shown), so let's hope......
Old 09-13-2010, 05:37 PM
Pauls Pauls is offline
Rep: 10 Posts: 11
I found some practical information on Euler factors for mast design. The subject is addressed by Pierre Gutelle. Translations of his work are available on this forum (the originals are in French). Gutelle has two charts, one for compression on adjacent panels and the other for length. The results from the two charts are combined and give a Euler factor for that particular combination. A useful piece of information I haven't found elsewhere.
Regards, Paul
Yawl mast design using Euler willfox Boat Design 2 01-12-2010 05:56 PM
Design Factors to Step The Main Mast. seasaltchap Sailboats 12 06-29-2007 09:25 PM
Aluminum Safety Factors Inquisitor Boat Design 9 12-07-2005 09:15 AM
neen some factors for a calculation Jeff Walkowiak Boatbuilding 1 04-13-2005 11:59 PM
mast design-how do you go upon calculating the effect of the sail on the mast??? airturb Sailboats 34 02-21-2005 09:55 AM
