| Each to there own method . lot depends on what you are glassing , the shape and size , temperature and weather conditions in general and working by your self or with others . Yes it can be a ongoing process of 3 coats one after the other. ![]()
| Peel Ply is Problem Quote:
I see no need to mix in q cells in this job, but if so, let me know. It is simply glassing over 30 year hull that had some age problems but not serious. Two layers of light cloth, clear resin, sanding for prime and paint... As to paint rollers, stick with mohair... I put up on SA and comments were very educational.
__________________ Leave a place better. Congress is the enemy! "All ya gotta know!" Dog. Winona. |
| plywood/epoxy question | woodrat | Wooden Boat Building and Restoration | 15 | 05-03-2009 10:13 PM |
| Fibreglass & resin as temp solution to pinhole | Conachair | Metal Boat Building | 4 | 01-20-2009 04:22 AM |
| Epoxy question | blakey1973 | Fiberglass and Composite Boat Building | 7 | 07-16-2007 03:49 PM |
| MAS epoxy question | alan white | Fiberglass and Composite Boat Building | 8 | 06-15-2007 03:46 PM |
| epoxy question, | zember311 | Boatbuilding | 5 | 05-23-2005 11:38 AM |
