| The effects of a wavy keel Kim Klaka, in "On the Performance of a Wavy Keel", concludes that "...waviness of more than 1 mm makes a significant difference in performance" on a sailing yacht of 10m length. See the interesting (albeit rough-and-ready approach) to the problem on page 45 of the May 2010 issue of Australian Naval Architect at: http://www.rina.org.uk/australian_naval_architect.html Does anyone know of any other theoretical or experimental work on this topic? Any experiences you'd like to share? Leo. |
| It is not a very scientific conclusion, since based upon a sample size of one! No references to what and how measurements were taken before and after….so more anecdotal than anything else. Despite it being “interesting”.. But as he noted historically often points the way. “Full scale tank tests of an International 10 Sq. meter Class canoe” by T.Tanner in RINA Trans 1961. He varied centreboard shape and profile. The biggest conclusion was the effect on the ratio of Lift/(speed)^2 and Drag/(speed)^2 was yaw. Yaw had a considerable effect on the results to those without. Thus how did Kim measure the yaw and its effects? |
| It is an interesting, but unfortunately too short report. However, it teases us to search for more info on the subject, and as such is more than welcome. On the other side, thanks to Leo's link I've discovered another very interesting fact - See the Letter to Editor at page 4, by mr. Martin Grimm. The concept of Lateral Force Estimator and of it's relation to passenger comfort is probably well-known to NA's, but not so much to YD's - because it's effects are mostly felt on the big-size vessels. I was one of ignorants up untill now. ![]() So thank you Leo for the unexpected development in my ethernal research for knowledge, I have something to read about in the next days. ![]() Cheers! |
| When Cote d'Or was in Auckland during a Whitbread stopover, skippered by Eric Tabarly with a crew of hotshot stars in the making as crew: Halvard Mabire, Roland Jourdane, Michel Desjoyeaux, Francois Carpente and numbers of others; when the big red maxi was on the hard, sharp eyed kiwis immediately saw there was a twist in the keel (I think it was Halvard's brother who made it) but the French guys just shrugged it off with a laugh - apparently they, and Cote d'Or's instruments could not ascertain any difference whether on port or starboard, upwind or down. Hmmmm! |
![]() I thought some of the aerodynamicists that lurk here might also have something to add. There would be a similar loss of lift on wings and tails of planes. Leo. |
Of course, there is also the waviness in the keel planform to consider. I suspect that a straight-edged planform could be made very accurately, but curved dorsal fin-like keels might be a bit tougher to get right, especially at the tip of the keel. That, of course, is where all the interesting stuff happens. All the best, Leo. |
| Im not suggesting you do. It was just an observation. However your other comment is more relevant and ‘juicy’. What roughness and straightness does a shark or dolphin have on its dorsal fin? Nature generally shows us the way before anyone can work out why! |
If only there were more days in an hour! Leo. |
0.35% of the chord (mentioned in the Australian Naval Architect article) would give +/-7 mm of thickness error for a 2 m chord, which is unacceptable by aeronautical standards. Guess thats why there is not much data available from that source. Cheers! |
Leo. |
| IIRC, C.J. Obara and C.P. van Dam wrote about wavyness in "Keel Design for Low Viscous Drag". Tha paper was presented at a Chesapeake Symposium and can be found on the SNAME Small Craft Papers CD.
__________________ Best regards, Søren Flening NOTE: This post is a natural product. The slight variations in spelling and grammar enhance its individual character and beauty and are in no way to be considered flaws or defects. |
| I'm not sure how you conclude it is a data set of one. While Kim's personal test was singular, this follows the empirical data presented in the references he noted - Ward, Hoerner (probably presenting Ward), and Powell. This article prompted our own interest in checking if waviness was significant on propeller performance. With the advent of pretty reasonable propeller blade scanning devices, we can begin to quantify this. I'll keep you updated on progress. Don |
| Appreciate, and looking forward to that! |
I'm not quite as practical, so I'll just see how slight "wobbles" in planform shape affects the lift of a thin wing with circular planform (because there is an exact solution available). I just need to work out a systematic way of introducing wobbles. All the best, Leo. |
| My biggest question is with the geometric definition of "waviness". What wave length and amplitude are we talking about? There are a number of papers about propeller CAM tooling marks and performance, but is this "waviness" or something else? When does "waviness" become roughness? Don |
| Mast rake effects | captjj | Sailboats | 0 | 05-02-2010 03:45 PM |
| effects of bieng overloaded | lfrancis | Sailboats | 4 | 04-25-2008 10:53 PM |
| Pendulums effects?? CB, CG.... | Wynand N | Boat Design | 12 | 11-30-2005 12:34 AM |
| scale effects | samh | Boat Design | 2 | 01-06-2005 07:09 AM |
| Wavy Hull | dave L | Boat Design | 10 | 09-23-2004 01:42 PM |
