| effects of bieng overloaded I have a pacific seacraft 25 I use it for cruising. Disp.=5700#. Full keel. With all the gear and what not, she is down in the water a bit. I realize she is slower, she may not perform as well. But I am concerned with the safety factors. Especially stability. And whatever else. |
| here is a look at waterline |
| here is a look at waterline she is about 4 inches over design. This pic doesn't tell much. just thought I would throw it in. Last edited by lfrancis : 04-25-2008 at 10:42 PM. Reason: delete |
| Stability depends on where the extra weight is concentrated. Low enough and stability is increased. It helps if all gear has been stowed safely, so that it isn't going to come unglued if you get knocked down. 5700# is a bit on the light side for 25 ft (the Flicka must be a bit heavier). A heavier boat usually has a larger waterplane (wider waterline beam and length, fuller ends) and it usually won't sink as much loaded with an equal weight. The penalty when you load down your boat is she won't have the sail area to push the boat as fast. I don't think a few inches make much difference stability-wise if heavy stores are stowed down low. Alan |
| Your boat is designed to accept weight well. She's a cruiser and shaped as such, so your concerns about her in a well burdened condition can be relaxed. She should carry 4,700 pounds in displacement with about 1,800 in ballast making for a healthy 37% ballast ratio. She's under canvassed at 236 sq.ft., which provides a low 13.4 SA/D, but she's intended as a blue water cruiser, not a racer, though light air sails could be carried. Crealock designed nice, wholesome boats and your will handle the load fine. Pay attention to Alan's comments about securely stowing and placing it low in the boat. Carry a spinnaker, big jib or code zero for light air work as these boats are not known for good performance in fickle winds. |
| Entry deadrise effects on performance. | tuantom | Boat Design | 6 | 09-20-2007 09:56 PM |
| effects of radically modifying the stern | bradles1330 | Boatbuilding | 1 | 08-09-2006 12:26 AM |
| Pendulums effects?? CB, CG.... | Wynand N | Boat Design | 12 | 11-30-2005 12:34 AM |
| scale effects | samh | Boat Design | 2 | 01-06-2005 07:09 AM |
