Old 12-21-2010, 10:15 PM
bean surchwell bean surchwell is offline
Rep: 10 Posts: 8
dual position rudder post
Bud Melges class c racing scow...
Has two positions for the rudder placement at 3' apart on center line.
Is this for the weight of the crew or a sailing tactic/direction?
Old 12-23-2010, 09:01 PM
Rep: 457 Posts: 1,404
Just guessing - I have a dual rudder setup on Groucho Marx (trimaran) but that is because the smaller one is for shallow water (and not much use if it is breezy) - whereas on the Melges boat it maybe because the forward one is a smaller blade for light weather and the other is larger and aft for heavier winds. Or it could be the other way round, I know nothing. Why don't you contact Buddy?
Old 12-24-2010, 10:22 AM
CutOnce CutOnce is offline
Rep: 205 Posts: 470
I seem to remember there were some scows built with the option to sail without the jib - and the alternate rudder position would be to balance the lateral resistance without the sail area.
CutOnce
Old 12-27-2010, 11:28 AM
Rep: 10 Posts: 8
thanks cutonce,
that makes sense
bean surchwell
Old 01-05-2011, 03:03 AM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
Are you sure about that? Every C scow I've seen has a single rudder, mounted at the stern on centerline. They have dual bilge boards, however. The bilge boards are used one at a time, like leeboards. (On a scow, you don't say, "Ready about," you say, "Board down.")
Other scows, like the E, A, and M16 have dual rudders that are down all the time. But, due to heel, the windward rudder is out of the water most of the time. The two tillers are linked together with a bar.
Tom Speer
Old 01-05-2011, 10:25 PM
Rep: 749 Posts: 1,314
Why not contact Melges boat works for the most authoritative answer? In the scow world there is also Johnson. They'll also have the answers. The C scow class probably has a secretary. Find the class organization on the web, contact the secretary or at least an active class member.
Rudder area for dual rudder teoman Boat Design 11 08-20-2010 04:16 PM
Dual helm stations, dual control heads for dual engines Scrumble Diesel Engines 2 02-02-2010 08:19 AM
bent s.s rudder post roscoewalsh Sailboats 9 08-09-2009 11:20 AM
Rudder Post in Carbon or Kevlar nero Multihulls 11 03-10-2009 06:40 AM
Rudder post KnottyBuoyz Boat Design 5 10-01-2007 01:39 PM
