  #31
Old 02-16-2008, 07:49 PM
Previous Member
Rep: 0 Posts: 0
I dont know what Michlet is........
Michlet uses Michell's thin ship theory for determining wave drag, has a choice of ITTC1957 or Grigson for viscous drag and also has a component for calculating transom drag.
I have found it gives reliable results for efficient hulls. The drag on such hulls tends to be dominated by viscous drag anyhow. Modern sailing craft are using more slender hulls such as trimarans, catamarans and canting keel yachts. These boats are designed to stay upright as well so heel is not a key concern.
If the hull is designed to plane then Savitsky gives reasonable accuracy. I was a little surprised that Michlet and Savitsky are not too different at the bottom end of the planing range.
There is a post here that compares Michlet with CFD and actual data:
http://boatdesign.net/forums/showthread.php?t=20497
Curves attached.
  #32
Old 02-17-2008, 06:31 AM
nico nico is offline
Rep: 52 Posts: 186
A nice article by Jason Ker. http://valenciasailing.blogspot.com/...-designer.html
____________
Nico
  #33
Old 02-17-2008, 07:08 AM
fastwave fastwave is offline
Rep: 36 Posts: 73
Nico,
to make it 150 point you need a lot more computing power than 16 processors for the runs I am talking about. Although the comptures might be cheap the licenses are no that cheap. so 80euro a point is very very difficult to get.
on 16 processors you will be lucky to get a point/24hours. You will only achive this if you have a very good and developed sustem in place.
With regards to people still saying that full appended runs are not possible, I only have to say the following:
1. It is done.
2. Quoting Ian Campell and Andy Claughton, is not representative. Both work, worked for the wolfson unit which is a big time fan of tank testing and not a great supporter of CFD.
people seem to know a lot about AC teams on this forum, but I wonder how many actually have a good insight of what is going on.
Const Fn for tank testing? GuestR01312011 Sailboats 9 11-18-2007 05:34 PM
Digital Tank Testing Of 1924 Hull RSLOOP Sailboats 8 02-25-2007 07:14 PM
DIY tank testing. Frosty Boat Design 6 11-30-2006 06:58 AM
Student needs help with TANK TESTING jamesflett Boat Design 12 07-20-2006 08:54 PM
Tank Testing TimClark Boat Design 8 01-11-2006 09:36 AM
