Old 12-28-2010, 07:43 PM
SuperPiper SuperPiper is offline
Men With Little Boats . .
Rep: 58 Posts: 277
Dr. Gerritsma Righting Moment
I tried to reply to a thread started by Yades but it is too old:
Mast Compression Loads
So I am starting a new thread for the same subject.
Yades showed an estimate of Righting Moment proposed by Dr. Gerritsma in 1993. I'm having trouble using the formula. I start to get plausible results if I substitute Sin(phi) for phi and Sin^2(phi) for phi^2 in the length coefficient. I've tried googling Dr. Gerritsma but I can't find a reference to this formula. Can someone help me?
Old 12-29-2010, 04:46 PM
Rep: 58 Posts: 277
I was able to access the thread, but when I tried to reply, a "more than 507 days old" message shut me down.
I'm very interested in the Gerritsma formula because of its simplicity. However, I'm wondering if there is a typo error because I don't recognize the results.
Has anybody tried it? Can you lead me to the original Gerritsma document?
Old 12-30-2010, 04:46 AM
Rep: 58 Posts: 277
Not much traffic on this thread. Did I mention that I need to know the righting moment so that I can hydrofoil on the boat's canting keel with a kite sail?
The Gerritsma formula uses basic boat dimensions to estimate righting moment. From that, GZ, AGZ and AVS can be approximated and I'm on my way to computing a STIX for this boat. Is anyone aware of a similar formula?
I just want to be able to say something like: "Based on the Gerritsma approximation, my boat has a STIX of 19.3."
Old 12-30-2010, 08:34 PM
sorenfdk sorenfdk is offline
Yacht Designer
Rep: 394 Posts: 508
I have some of Dr. Gerritsmas papers somewhere. I'll have a look and see if I can find something.
In the meantime, there's something else about this formula: The RM seems to be dependant on the speed. This makes me think that it should only be used in certain, specific connections.
Best regards,
Søren Flening
NOTE: This post is a natural product. The slight variations in spelling and grammar enhance its individual character and beauty and are in no way to be considered flaws or defects.
Old 12-31-2010, 02:50 AM
Rep: 58 Posts: 277
Sorenfdk, you are absolutely correct!
I finally found a reference to this formula in a van Oossanen article: http://www.swzonline.nl/swz-archief/...ng%20craft.pdf
The small boat guys are so used to getting beat up for their size, that I assumed the 2nd half of the formula was a coefficient relating increased stability to LWL. It is actually FSSL, a factor for speed stability loss.
Shows what little I know.
I always thought a sailboat was MORE stable with way on, with pressure on the sails. But the article explains that a displacement boat will sail in a wave trough and there is no water in that moving hole to support the hull. The boat is more likely to tip over.
And this is cool: the longer the LWL the bigger the trough, so the big boats are LESS stable than the little guys. Woohoo!
The first half of the formula is the static stability approximation. But being perfectly sinusoidal implies that every boat has an AVS of 180 degrees. This is not as practical as I had imagined. Apparently the formula may be close for angles of heel less than 30 degrees.
Happy New Year.
Rig Weight Reduction vs Righting Moment Gashmore Stability 4 12-08-2009 11:12 AM
Righting Moment Question - amolitor Boat Design 2 01-14-2009 03:04 PM
Righting Moment Stevens47 Stability 2 04-23-2008 09:37 AM
righting moment of a keel rapscallion Stability 4 10-17-2007 09:15 AM
Twin Keel Righting Moment Willallison Sailboats 23 04-04-2006 12:22 AM
