Old 12-29-2011, 11:38 AM
folotp's Avatar
folotp folotp is offline
Rep: 10 Posts: 4
Downwind lift possible with a non-rotating freestanding mast?
Hi,
I am wondering if it is possible for the sails to generate lift when going downwind on a non-rotating freestanding mast. Like on a Freedom rig for example. Would the boom have to go too far forward?
Thanks.
Pierre-André
Old 12-29-2011, 05:52 PM
Rep: 749 Posts: 1,314
Pierre; When you say lift, are you referring to vertical lift? If so you will need to introduce a vertical component to the force of the sail. That implies that the mast is raked, as on a windsurfer. More rake means more vertical lift and diminished forward drive. Vector sums at work.
Old 01-01-2012, 04:42 AM
Perm Stress's Avatar
Perm Stress Perm Stress is offline
Rep: 323 Posts: 523
Windsurfer style freedom rigs with wrap-around sails, certainly.
If dead downwind, booms have to be about 30 or so degrees forward from abeam.
The side effect is force component to "windward" -opposite side from the boom.
All the stresses in my designs are 95% of permissible.
Old 01-04-2012, 07:07 PM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
Originally Posted by folotp View Post
Hi,
Thanks.
Pierre-André
You need to reduce the angle of attack below the stall angle. The boom has to go well forward to accomplish this. It can't do that when there are shrouds, and the gooseneck is probably not going to have enough freedom of motion on a fixed mast.
A fixed, cantilevered round mast could do it, with the sail and gooseneck rotating around the mast.
Tom Speer
rotating freestanding wing mast section and mast bend Timothy Sailboats 6 06-25-2010 11:53 AM
bearings for freestanding rotating mast Timothy Sailboats 2 08-11-2009 02:52 PM
Build a Freestanding or buy a Traditional mast? Kaptin-Jer Fiberglass and Composite Boat Building 30 05-07-2008 02:06 AM
Rotating wing mast john olsson Multihulls 4 06-11-2007 07:06 AM
is it possible to have a freestanding mast on a open 60"? yoshi Boat Design 8 03-18-2005 10:49 AM
