Old 05-05-2006, 12:16 PM
Ctskip Ctskip is offline
Rep: 10 Posts: 9
Doing a walk-thru transom
I have a 1983 31 ft Allmand sailboat with a propane locker for a rear seat in the cockpit.I would like to cut out this locker and make it a walk-thru tramsom.The walls and floor of the locker will remain as they are now(factory).Will I create any problems in cutting away the top two feet of the transom and as wide as the boarding ladder? It seems to me to be a natural but I would like to hear from maybe someone who knows design and or a structural engineer. Heres hoping. Thanks all
Keep it up,
Ctskip
Old 05-08-2006, 07:50 AM
kenJ kenJ is offline
Rep: 56 Posts: 323
Re: Walk thru
Many new boats have them, but they were designed that way. Assume you have a spit backstay so it won't be in the way. I think it can be done, but you may need to reinforce the remaining transom so the spit backstay doesn't "squeeze" your walk thru as the transom flexes under backstay load. You could possibly fashion a new tightly fitting removable seat that fits in the space to help the amount of room the transomhas to flex.
Transom modification jimhales Fiberglass and Composite Boat Building 11 03-09-2006 08:41 PM
Dunkirk 24 Walk Around Molds for sale Dunkirk Marketplace 3 10-26-2005 04:00 PM
Prop-walk rod fox Propulsion 7 11-08-2004 01:34 PM
transom bammy the bass Fiberglass and Composite Boat Building 1 09-27-2004 06:03 PM
Outboard Bracket on 22 walk Cush8181 Powerboats 0 06-08-2004 05:07 PM
