| DIY Sportboat; best designs? I have been hunting around for home build sportboat plans in the 8 meter range, and have found the didi 26, Alik's free 8 meter plans, the i550, Colson's designs, the GT6... Am I missing any interesting designs out there? My dad was thinking about building an 8 meter sportboat, and he definitely want's to build using wood. He want's a sailplan with a sprit, and a lifting or swing keel.
__________________ http://janetcg32.blogspot.com |
| simple....if a Kiwi didnt design it dont build it. Elliott Thompson Shaw etc
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
| Kevin Dibley also has an 8m I've built and own a Colson 8. Not a hardcore raceboat, but a good mix of race and the ability to cruise with comfort. If you google Colson 8 you'll see my website of the build. Cheers Mojo |
| Stealth 8's aswell, but these are foam/ carbon. |
| Colson 8 Quote:
You sure did a good job on finishing the boat! Looks great....
__________________ yes, it is a revolution ---"So (yet) another new world begins." Andrew Hurst, editor of Seahorse magazine, August,2011 |
| Here is a Didi 26 in alloy. It appears he decided to build from 3mm alloy instead of 12mm plywood . What do you guys think of this substitution? http://www.mbyachts.com/start.html |
He has a full on 27 footer (currently not for wood, but maybe could be modified in the construction plan) and the Shilshoal 27 (for wood construction) that has some accomodation. http://biekerboats.com/Bieker_Boats/New.html |
| have you examined the Kavalier 800? It is a great design, easy to build, and the plans are free. It is at: http://www.boatdesign.net/nyd/K800/ |
| The K800 is a great design.. I'm a big fan of Alik's work. But, I don't consider the K800 a sportboat... The crayola is pretty sporty though. The pluto 800 is more like what I'm looking for.
| Have you looked at an i550?
__________________ Sunkel-Lozell Boat Design |
| The i550 is a great design that is gaining traction as a one design class... he was looking for something a tad bigger. too bad there is no such thing as an i750
| Alik, was the keel swept (20deg) to get CG and CLR in their right positions or was this a design parameter for the outset and canard added? |
| The boat was designed like that, from beginning: twin rudders, swept bulbkeel and canard. One this photo old keel is shown; the new one got shorter bulb. |
| DIY job?! | Bullterrier | Fiberglass and Composite Boat Building | 5 | 05-12-2010 06:28 AM |
| advice design of a carbon fibre sportboat mast | JorgenBeyer | Sailboats | 0 | 01-25-2010 07:32 AM |
| Trailerable sportboat weekender? | Steam Flyer | Sailboats | 48 | 08-12-2009 05:12 PM |
| nicest throttles / shifters for recreational sportboat? | Tim.M | OnBoard Electronics & Controls | 15 | 04-25-2009 05:34 PM |
| Teleflex DIY | Mack77 | Powerboats | 0 | 06-24-2008 08:20 PM |
